worksheet image
fabrica
is there anyway to control the appearance of a window in the worksheet image function? (wireframe mode) ie. the elevation of the window is a light grey compared to the text / text boxes?
the only way I can figure out to do a normal window schedule is two worksheets.
1- standard with all the details / id / sizes etc as normal
2- an image only worksheet at 1:1 which then can use viewports to the sheet of each window - (allows windows to be horizontal across page rather than all vertical.) - obviously not a quick workflow!
vectorworks need to give this a serious update - sub-standard BIM at the moment...
