Erik Buijs Posted May 23, 2003 Share Posted May 23, 2003 Hi, I am using Vectorworks Pro 9.5.1 on PC and I have a question about exporting rendered perspective views to eps format. When I do so the files become huge! (20 - 25 Mb each!)Is there something I can do about it? I need this eps format, because it's the only way to be compatible with our press-office. Or should I use another format? Quote Link to comment
Guest Posted May 23, 2003 Share Posted May 23, 2003 When you export the files to eps or image file format, the files to grow in size. If you need to retain the vectored format, eps is the best choice. DXF or DWG keeps the file size smaller, but that format may not be practical for you. Quote Link to comment
Bryan_dup1 Posted May 23, 2003 Share Posted May 23, 2003 Most people on the graphic side of things are used to recieving files and having to scale up from 10% actual size to full size. You could really make the files much smaller that way. Quote Link to comment
