Segments of Polylines disappear
benboggs
I am having to draw dumb contours to eliminate all the jaggedness of the model generated contours. Also - the model wants to close contours when I do not want it to (trying to create deliberate low points and swales - but model wants to draw 105' contour through pad modifier stakes with elevations of 103, and 104).
My issue is when I draw polylines over top of the contours - segments disappear, the first part of the polyline goes away, or the last segment. Does connecting them to contours with elevations cause this?
Thoughts?
No - the polylines do not have a solid fill. I am more or less tracing the site model generated finished contours to create smoother finished contours for bid documents. When I go to trace the model contour (start at one end) and draw a polyline (with multiple arcs, straight segment) and when I am done drawing the polyline - sometimes segments of the poly line will disappear. Attached is an example.
