Vectorworks, Inc Employee Neil Barman Posted February 15, 2016 Vectorworks, Inc Employee Share Posted February 15, 2016 Are there existing nodes for Align & Distribute commands? Or must these actions currently be built from a combination of the Move, Math and Point 2D nodes? Thanks, -Neil Quote Link to comment
Jonathan Pickup Posted February 15, 2016 Share Posted February 15, 2016 I would like to know this as well. I'm trying to build a marionette object and I would like the text to be centred on the object. My solution at the moment: set my text alignment to centre top using the Set Text Properties node] moving the text to 0,0 then move the text to the centre of my rectangle is there a better way? Quote Link to comment
DomC Posted February 15, 2016 Share Posted February 15, 2016 Hi Maybe you could use PtArrayStartEnd for calculation Point between two points. https://techboard.vectorworks.net/ubbthreads.php?ubb=showflat&Number=223249#Post223249 And then place your objects with The "PutByRefPoint"-Node https://techboard.vectorworks.net/ubbthreads.php?ubb=showflat&Number=221843#Post221843 Also the "PutBy RefPoint" can align existing objects to specific axis. Some instructions to to this: Quote Link to comment
