AlanW Posted February 12, 2016 Share Posted February 12, 2016 (edited) Hi, In the 005.2-Color Range Saved view you have placed a negative node between each of the RGB components and an abs after the Remap Domain. Why is this done? the abs removes the negative property so why place it there? Also the Getxyz and Point3d in this location is this just another way of separating the RGB numbers at first and then placing the 3 separate numbers back into a (0,0,0) format? Thanks Edited February 12, 2016 by Alan Woodwell Quote Link to comment
Vectorworks, Inc Employee SBarrettWalker Posted February 12, 2016 Vectorworks, Inc Employee Share Posted February 12, 2016 Hey Alan- so the reason I use a negative node is to invert the values - if you take them out you notice that the colors switch their order - It was a way to make the "max" color match the "max" value. They are not truly necessary - there are other ways to make this work. (I had to double check this because when I work on definitions for a while - things can get redundant because I find different ways to solve problems as I work, but I believe it is true.) Quote Link to comment
AlanW Posted February 13, 2016 Author Share Posted February 13, 2016 Hi, I an looking for the Chunk List and Flatten list nodes that were listed in the Webinar, were they supplied in one of the 2 files in the forum?? Thanks Quote Link to comment
AlanW Posted February 14, 2016 Author Share Posted February 14, 2016 (edited) Ok, Stop looking found the Chunk List but not the transpose and Flatten List. :blush: . Edited February 14, 2016 by Alan Woodwell Quote Link to comment
Vectorworks, Inc Employee SBarrettWalker Posted February 16, 2016 Vectorworks, Inc Employee Share Posted February 16, 2016 Ah, that file was not included - here it is. Quote Link to comment
Vectorworks, Inc Employee PVA - Admin Posted February 16, 2016 Vectorworks, Inc Employee Share Posted February 16, 2016 Ah, that file was not included - here it is. Added to the main thread links as well. Quote Link to comment
