AlanW Posted February 5, 2016 Share Posted February 5, 2016 (edited) Hi, Trying to work out the chord of a circle based on the angle and radius. This involves Sin but the Sin nodes dont appear to give the same result as in a Sin chart. Sin of 30deg =0.500 I am sure someone can point me in the right direction. Thanks Edited February 5, 2016 by Alan Woodwell Quote Link to comment
Marionette Maven Marissa Farrell Posted February 5, 2016 Marionette Maven Share Posted February 5, 2016 Hey Alan! The sine node takes in an angle in radians. Since you're providing it with an angle in degrees, the output will be incorrect. There's a node in the Math section (Angular Conversion subsection) called "Deg2Rad" which will take an angle in degrees and convert it to radians. I'm attaching an example. I hope this helps! Quote Link to comment
AlanW Posted February 5, 2016 Author Share Posted February 5, 2016 Marissa, Thank you, I have got the wrapper to do what I want now. Thanks Quote Link to comment
