Script for Lineweights
rosebud5
Hi, I am trying to create a script in order to change a selection (line, etc.) to a different line weight without having to go through the attributes palette dropdown. I know that you can create a dotted line type without any gaps in the resource browser as a line type but you do not have any control over line weight. I have a bunch of line weight scripts that I use all the time but they do not work on currently drawn items. Would like to create a custom tool/attribute that changes the currently selected line with just a click. Thanks,
  • 2 weeks later...
Hi, thanks for the response. I am not very adept at coding and every time put in the code that you referenced it changes all the objects to the new line weight, not just the selected object. Any suggestions: this is what I have put in the script editor:
PROCEDURE LineWeightChange;
{ © Petri Sakkinen 2008 }
CONST { substitute these with the required values }
oldWeight = 2;
newWeight = 20;
PROCEDURE ChangeIt (h : HANDLE);
BEGIN
SETLW(h, newWeight);
END;
BEGIN
FOREACHOBJECT(ChangeIt, LW = oldWeight);
END;
RUN(LineWeightChange);
OK, do I tried this out and it still did not seem to work
oldWeight = 2;
newWeight = 20;
BEGIN
END;
BEGIN
FOREACHOBJECT(ChangeIt, LW = selectedobject);
END;
any suggestions, thanks
{ (c) Petri Sakkinen 2008 }
oldWeight = 2;
newWeight = 20;
BEGIN
END;
BEGIN
FOREACHOBJECT(ChangeIt, ((LW=oldWeight)&(SEL=TRUE)));
END;
the ForEachObject Call has two arguments
- Callback function, A block of code to be run on the objects found via the criteria
- Criteria, The criteria used to find objects you're wanting the callback function to be run on
More Info :
http://developer.vectorworks.net/index.php/VS:ForEachObject
What Petri's code is doing is looking for all objects that have a line weight size specified by the oldWeight variable. ie
oldWeight = 2;
(LW=oldWeight)
I added the SEL=True to the criteria to find only the objects that are selected.
More Info on Criterias can be found here:
http://developer.vectorworks.net/index.php/VS:Search_Criteria
hth
Tui
you are awesome!! thank you so much for laying that out. it totally worked and makes things a lot easier. So, if I want to have the the code change any line weight to the specified line weight, could I put multiple values into code like
oldWeight = 2, 5, 10, 20;
I tried that and it did not work so I think that i am just writing it wrong,
Again, thank you for you help, greatly appreciated!
There are a number of ways to tackle this.
Below is one way of the many ways.
Have a look at the vectorscript language guide to get a hang of the syntax required to know. Vectorscript is based off of the Pascal language.
I have jumped from VS to python, so my syntax may be incorrect. Double check if it works on an empty file, just in case crashes etc. occur. That is my disclaimer by the way. hehe
I am by no means an expert, just an eager learner like yourself no doubt.
{ (c) twk based off of original code by Petri Sakkinen 2008 }
CONST
newWeight = 20;
VAR
	oldLW : INTEGER;
BEGIN
	oldLW := GetLW(h);
	IF (oldLW = 2) OR (oldLW = 5) OR (oldLW = 10) OR (oldLW = 20) THEN
		SetLW(h, newWeight);
END;
BEGIN
FOREACHOBJECT(ChangeIt, ((SEL=TRUE)));
END;
