RuudB Posted January 29, 2016 Share Posted January 29, 2016 Hello all, I faced different problems with the "Path Extrude" node. 1. The output is not able to used for "Boolean". 2. The options had to be set inside the script. I solved both of the problems, but I noticed it still needs some attention. The profile rotation is not recognized by the script. Probably some script line needs to be added. I will also look to this, but help is welcome. Ruud Quote Link to comment
AlanW Posted January 30, 2016 Share Posted January 30, 2016 Hi, When you say the profile rotation is not recognized by the script, can you give an example. In the attached I can rotate the profile, not sure if this is what you need. Quote Link to comment
RuudB Posted February 2, 2016 Author Share Posted February 2, 2016 He Alan, I will sent you a test file with it. If you do "Path Extrude" with the "Fix profile" on, there is a difference when using the menu or Marionette. In the menu the axes of the plane are used as basis, in Marionette the axes of the file are used as basis. This confuses me. Ruud Quote Link to comment
AlanW Posted February 2, 2016 Share Posted February 2, 2016 Hi, Yea I don't see any difference between fixing the profile and not. But I did discover an exciting possibility for the path extrude. See file with scale exponentially Will look into it more. Quote Link to comment
