RuudB
Node Path Extrude (fixed and extended)
Hello all,
I faced different problems with the "Path Extrude" node.
1. The output is not able to used for "Boolean".
2. The options had to be set inside the script.
I solved both of the problems, but I noticed it still needs some attention. The profile rotation is not recognized by the script. Probably some script line needs to be added. I will also look to this, but help is welcome.
Ruud
Hi,
When you say the profile rotation is not recognized by the script, can you give an example.
In the attached I can rotate the profile, not sure if this is what you need.
He Alan,
I will sent you a test file with it. If you do "Path Extrude" with the "Fix profile" on, there is a difference when using the menu or Marionette. In the menu the axes of the plane are used as basis, in Marionette the axes of the file are used as basis. This confuses me.
Ruud
Hi,
Yea I don't see any difference between fixing the profile and not.
But I did discover an exciting possibility for the path extrude.
See file with scale exponentially
Will look into it more.
