AlanW 527 Posted January 25, 2016 Hi, Could someone show and example network for lofting please. Thanks Quote Share this post Link to post
Mark Flamer 0 Posted January 26, 2016 Here is an example using a loft node. Each time its runs you will get a different curvy vase thing. The trick with this node is that it wants a group of curves instead of just a list. Maybe we should change that. Quote Share this post Link to post
AlanW 527 Posted January 27, 2016 Thankyou, and love the use of the new Random Node. Regards Quote Share this post Link to post
AlanW 527 Posted January 27, 2016 (edited) Hi, In the following lofting example I have offset contours and would like to loft these and I need to ungroup the offset nurbs curves to loft them but it appears the Ungroup Node is not working. If you add the last loft Nurb the curves vanish. I have copied the resultant curves manually, ungrouped and lofted them and all ok. So weird, manually ungroup works to loft. ungroup in Marionette does not work but adding the group node again works.???? Any ideas??? Also what would be a good way to select the individual curves and either move or scale each one? Edited January 27, 2016 by Alan Woodwell Quote Share this post Link to post
Kevin McAllister 1,153 Posted January 28, 2016 Alan, I think its related to the grouping issues in this earlier thread - https://techboard.vectorworks.net/ubbthreads.php?ubb=showflat&Main=43189&Number=216373#Post216373 There is a bug here somewhere.... Kevin Quote Share this post Link to post
AlanW 527 Posted January 28, 2016 (edited) Thanks for this Kevin, Its really interesting looking at the different ways people go about creating an object. Would never considered doing it the way (in that post) but at present it is all about understanding what Marionette does. Edited January 28, 2016 by Alan Woodwell Quote Share this post Link to post
AlanW 527 Posted January 28, 2016 (edited) Hi, Understanding this network downloaded from above post, BUT, the NURBS surface works but when I switch over to a NURBS Curve I have an instant crash. I was reading the Get Point as Index 1 was for NURBS Curves and Index 2 for NURBS surface. Could you let me know where I am going wrong please? Thanks I am beginning to feel rather dumb asking all these questions and no one else is. Is everyone else getting all this or is it only me? This is quiet interesting for some side learning. https://www.khanacademy.org/math/linear-algebra/vectors_and_spaces/dot_cross_products/v/normal-vector-from-plane-equation Also interesting variations in shapes you get when you simply adjust the direction of the contours in this network. Edited January 28, 2016 by Alan Woodwell Quote Share this post Link to post
Kevin McAllister 1,153 Posted January 28, 2016 I am beginning to feel rather dumb asking all these questions and no one else is. Is everyone else getting all this or is it only me? Alan, I was asking lots of questions back in September/October when I was experimenting with Marionette. It is complex and not quite finished development to the stage many of us need. There also isn't proper documentation. I became busy and put it aside for a while so that some of these issued could be sorted out. I will be experimenting and asking questions again when I have more time... Please don't stop asking things. I really enjoy reading these posts and the replies. Kevin (They're going to have to step up documentation/development or they will lose the cross platform visual scripting battle. NV were the first in beta (I would call the release beta) but now there is a beta version of Grasshopper (Rhino) for Mac which is being aggressively moved forward. McNeel has an advantage because all of the online tutorial materials for the Windows version, which are vast, directly apply to the Mac version.) Quote Share this post Link to post
PVA - Jim 2,390 Posted January 28, 2016 Do not stop asking. There is a rule commonly referred to as the "1%" rule for online communities. https://en.wikipedia.org/wiki/1%25_rule_(Internet_culture) This holds pretty true for our community board here (Though its about 5-10% in our case depending on the month). A huge number of users whom have never posted regularly -or at all- view these posts on a highly regular basis. A lot of this in marionettes case is due to the lack of documentation I have no doubt, but a large portion of it can be attributed to the bias for people to err on the side of NOT asking questions. But they are watching and they are reading and learning from every question asked and every mistake made here on both sides. Please continue to poke at us for information. I can't help a great deal with Marionette specifically (yet) but fear not, large amounts of resources are being aimed at this section of the application now and any discussion that occurs here will help shape Marionette as we keep developing it. Quote Share this post Link to post
RuudB 0 Posted January 28, 2016 Hello all, I'm also experimenting in using the loft node. In the menu of Vectorworks, there is a lot possible when making surfaces out of curves. I tried six different ways of making a surface out of curves. For two of them I succeeded when using Marionette, for the other four I have no idea how to. I hope someone can help me with this. See the file for details. Ruud Quote Share this post Link to post
AlanW 527 Posted January 29, 2016 (edited) Hi, If you click on the loft surface node you have 3 options rule, close & solid. If you choose rule and or solid you should get a result. Use the same principle as doing it in VW normally. HTH Edited January 29, 2016 by Alan Woodwell Quote Share this post Link to post
RuudB 0 Posted January 29, 2016 I know these options exist, but these are not where I'm looking for. In the top menu you can also chose between "No Rail Mode, One Rail Mode, Birail Sweep Mode". I'm looking for these options. I don't know if have to activate them with a different function, or to use "SetRfield". Quote Share this post Link to post
Kevin McAllister 1,153 Posted January 29, 2016 I know these options exist, but these are not where I'm looking for. In the top menu you can also chose between "No Rail Mode, One Rail Mode, Birail Sweep Mode". I'm looking for these options. I don't know if have to activate them with a different function, or to use "SetRfield". I don't think you can. The node uses the CreateLoftSurfaces Vectorscript command which seems to only create a loft from cross section curves - http://developer.vectorworks.net/index.php/VS:CreateLoftSurfaces Unfortunately in many instances the Marionette nodes are not the same as VW tools which are custom coded. Kevin Quote Share this post Link to post
RuudB 0 Posted January 29, 2016 I was thinking the same. In that case I will try finding the custom code. Someone should know it. Ruud Quote Share this post Link to post
AlanW 527 Posted January 31, 2016 just testing this out it appears that it automatically does the various options based on which nurbs curves you choose. The last one cant figure as it appears to create 2 separate Curves. It says that they will be lofted in order of connecting to the group. HTH Quote Share this post Link to post
Patrick Winkler 47 Posted February 1, 2016 (edited) The close and solid options of 'Loft Surface'-Node seem not to work correctly (see attached files) Edited February 1, 2016 by Patrick Winkler Quote Share this post Link to post
AlanW 527 Posted February 2, 2016 (edited) Hi Patrick. It closes if you use 1 and not -1 in your wrapper (Remove the duplicate Angle). If you check your output from your Split Circle Angle you only have 9 finishing at 234 degrees and you need to close at 360 to complete the circle. Well that's how I see it. HTH Edited February 2, 2016 by Alan Woodwell Quote Share this post Link to post
Patrick Winkler 47 Posted February 2, 2016 (edited) Hi Alan, Just try it by hand and you will see what I mean. If I close it by rotating the profile 360 degree I don't need the close option anymore. Edited February 2, 2016 by Patrick Winkler Quote Share this post Link to post
