VW2016 Crash on Extrude Along Path
Hi all, I'm having trouble with extruding a 2d polygon along a nurbs curve.
The 2d polygon is one of many to be extruded along this path, so it is slightly offset from the path, and thus I select the [fix profile] option. I noticed that if I deselect [fix profile] the crash does not occur..
Every time I run this command I get 'VW 2016 needs to close down' ?
Does anyone else get the same crash as I do?
Edited by CarlJdP
@Benson Shaw
Thank you, the stacked vertex explains it :) Would be nice though if Vectorworks could catch this exception.
@JimW / @MarissaF
Would be nice, with a lot of the tools, if the FAILED error message could state why the operation failed, or which objects caused it..
@Benson Shaw
@JimW / @MarissaF
Adding this thread to the existing request for more informative solid modeling error messages.
I would say a visual indicator would be a good wishlist item, I'll submit that. However, I would also say a pre-check might be in order so that an EAP could at the very least WARN a user about a stacked vertex, and ideally either fix it automatically or avoid it becoming an issue.
