Kimcz
Wall types
When I set up, or try to edit wall types, the OK button is off the bottom of the screen. I am on the limit of resolution of the screen.
I cannot save by "enter" on Windows 7. Does anybody know how I can overcome this problem? I am using VW16.
So if you go to Resource browser and click on a wall style and click edit do you get the wall style to edit?
Yes, I can get the wall type to edit. I can edit, but cannot get to the OK button which is off the screen at the bottom. I cannot re-size the edit window to reach the button.
Try some experiments and see if you can find a key combination that will select the OK button.
Open a different dialog box where you can see and reach the OK button. Try different option of Enter, Return and those keys with different modifier keys (shift, alt, ctrl) and see which one triggers the OK button.
Then try that combination on the wall type edit box and see if it works.
Or see if you can Tab to the button and then use Enter to click it. Maybe start at the top and use Shift-Tab to go backwards.
Here on my Mac, Enter always clicks the OK button.
Otherwise you are going to have to upgrade the resolution of your monitor.
Screen Resolution 1440 x 900 minimum
1920 x 1080 or higher recommended
