output drawing order
J. Miller
  • Marionette Maven
Hi!
So there are a few threads that have already been started on this topic, and it's a tricky one to answer at the moment.
Towards the end of this first thread explains my current knowledge of stacking order within Marionette, and links to
this thread, which contains a file with Stacking Order nodes.
In short, to summarize without visiting the other threads:
Stacking Order does not behave as expected when in an unwrapped network, it can vary in a number of ways. This is being looked into by myself and one of the Engineers for a solution.
In a Marionette Object or a Wrapper, stacking order appears to behave as intended.
The second link will bring you to a thread where Stephen has posted some stacking order nodes - "Send Nodes" (near the bottom, posted on Jan 07, 2016)
  • 1 year later...
On 1/18/2016 at 4:12 PM, MarissaF said:
Hi!
The thread links go to the old forum. is there a way to easily find these threads again?
When I have several objects that are created by a network and can't be ordered the way I want them initially, I will put them through an ordered list at the end, then through a group node, then an ungroup node. This will put them in the correct order as well as a single Marionette group.
  • 2 years later...
My network creates two polygons, that overlap partially. I want one specific polygon on top of the other and I'don't get it...?
On 1/19/2016 at 5:50 PM, J. Miller said:
just experimenting...
I used an "ordered list" data flow node and placed the 2D objects in the order i wanted them to be drawn. it worked just fine
Jeff
Maybe I missed something, but it didn't work. I placed a 'ordered list' node at the end. Connected the polygon to be on top to item0 and the second to item1 but it doesn't help.
I added a group node and an ungroup node but it still doesn't work.
Can anybody help?
Thank you all
VvierA
  • 4 years later...
Using if nodes is possible;
it's kind of an effort to put something as input fo each (true and false)
Or am I missing any "put in nothing" node?
in 2023 if nothing is added it seems to be "1" in 2022 it was "0"
fo example if I create a 2D rectangle and have no valid input it generates a 1x1 square.
