AlanW
Objs by Crit Node
Hi,
Could someone provide an example use for this node?
From the Inputs section.
I notice it in this script in one of the examples.
Thanks.
Edited by Alan Woodwell
Hi alan it's pretty simple.
In the OIP of the ObjByCriteria theres a filed for the criteria
which could be:
N='controlGeom1' (Name = 'controlGeom1')
T=Rect (Type = Rectangle)
the Node will deliver all Objects of the document (or only of the layer??) which match the criteria.
Here is a list with the criteria:
http://developer.vectorworks.net/index.php/VS:Function_Reference_Appendix#attrCrit
An easy method to create criteria statements can be found in the script editor (lokk at the screenshot).
regards
Edited by Patrick Winkler
Great, thanks for this.
So simple if you know, like anything.
I am thinking Criteria like the worksheets but I will look over the area you recommended.
Thanks.
Hi,
Could you post a simple example please, Can't seen to get any output.
Also note that the Node in the image I attached has an input and output where as the the one from the program only has an output.
Thanks
