GlueDT92
Zero Supression (or not)
It would be really awesome if there was a way to force VW to add in zero's even if the dimension does not require it (i.e. 0'-x" or x'-0") without having to go in and manually edit each dimension and type in the zeros.
I find that by including a full dimension (X'-Y") in my construction drawings, I am able to reduce carpenter error, so I almost always want to include the full dimension, which means I have to manually edit lots of my dimensions before plotting!
3 answers to this question
I had actually thought that was possible, since you can enable leading and trailing zeros in Units, then set the units to Feet and Inches, but it does in fact only show 0" rather than 0'0"
Submitting request now.
Yeah, I set that up, and then spent an hour trying to figure out what I was doing wrong before deciding that VW was just not going to do what I wanted!
