t_and
Visualisation problem - bugged file?
Hello,
I was just working with my file and switched to a new layer. When going back to an other layer with drawings it seems that it bugged. They all turned to look like this
[img:center]http://s17.postimg.org/mq9bz939b/Captura.png[/img]
Thing is, while I zoom in&out I can see the drawing properly, but when I stop it looks weird as the picture shows.
Is there a regen option like in autocad?
Thanks a lot, it's a really important file for me
Share this post
Link to post
I like the look ....
Normally the typical questions are :
- Is your drawing far from internalorigin ?
- Does your graphics card meet the VW hardware recommendations ?
- Are you sure that the stronger GPU is assigned to VW (Laptop/energy settings) ?
- Do you use the latest GPU drivers ?
And it is helpful to put your hardware specs, OS and VW version number into
your signature.
Share this post
Link to post
Hello and thanks for your help!
- Actually no, it's pretty close.
- I guess it does, so far it did without any problem. It worked fine until today...
- I'm not sure how to do that :S
- Yes, they are up to date!
Done for the signature ;) My apologies!
Share this post
Link to post
See what happens if you copy a section to a new file.
Also try selecting a section and move to another desingn layer then back.
Share this post
Link to post
Hi,
I'm also curious if there is a regen like in autocad because I'm having trouble in dimensions.
if i try to replace or erase a text style in the resource manager and replace it with a new text style
the dimensions changes and the only solution i can come up with is somehow just move dimension or change text style in object info, is there a shorter way to regenerate all dimensions at once?
Share this post
Link to post
On 12/26/2018 at 2:24 AM, Haners said:
Hi,
I think Tools > Utilities > Reset All Plugins and/or Update Plugin Objects will do this.
Share this post
Link to post
