Patrick Winkler Posted January 7, 2016 Share Posted January 7, 2016 (edited) This is a little script to create Spirals. Excepts the 'PopUp'- and the 'Switch Case'-Node all nodes are native. I also created two wrappers: -'GetPointsOnCircle' -'DegreeToRadiant' reagards Patrick Edited January 7, 2016 by Patrick Winkler Quote Link to comment
AlanW Posted January 8, 2016 Share Posted January 8, 2016 Nice, thanks for the additional nodes. Another way to make a spring is to use the sweep node. See attached Quote Link to comment
Patrick Winkler Posted January 8, 2016 Author Share Posted January 8, 2016 thanks Alan, I had no idea that the sweep node is that mighty. The profile input (circle and locus) looks really abstract to me, I try understand the mechanism behind it. regards Quote Link to comment
AlanW Posted January 8, 2016 Share Posted January 8, 2016 (edited) Hi, Its a pretty simple item, as with normal sweeping the sweep looks for a centre and it is the node, so all you have to do is to move the node out and you get a bigger radius and the offset just does what it says. Have a look at the sweep items in this post. https://techboard.vectorworks.net/ubbthreads.php?ubb=showflat&Number=221312#Post221312 In the VW file you can adjust the setting to obtain different shaped springs by just changing the sweep input. Edited January 8, 2016 by Alan Woodwell Quote Link to comment
STERNontwerp Posted July 5, 2016 Share Posted July 5, 2016 I never thought of a shell as a spiral. But that is the result of entering the variables : 1, 10, 1, 10, 30. Quote Link to comment
