Patrick Winkler
Spiral - Network / Switch Case Node
This is a little script to create Spirals.
Excepts the 'PopUp'- and the 'Switch Case'-Node all nodes are native.
I also created two wrappers:
-'GetPointsOnCircle'
-'DegreeToRadiant'
reagards
Patrick
Edited by Patrick Winkler
Nice, thanks for the additional nodes.
Another way to make a spring is to use the sweep node.
See attached
thanks Alan,
I had no idea that the sweep node is that mighty.
The profile input (circle and locus) looks really abstract to me, I try understand the mechanism behind it.
regards
Hi,
Its a pretty simple item, as with normal sweeping the sweep looks for a centre and it is the node, so all you have to do is to move the node out and you get a bigger radius and the offset just does what it says.
Have a look at the sweep items in this post.
https://techboard.vectorworks.net/ubbthreads.php?ubb=showflat&Number=221312#Post221312
In the VW file you can adjust the setting to obtain different shaped springs by just changing the sweep input.
Edited by Alan Woodwell
