Render time
Andy Broomell
In VW2016 (which displays a completed render time in the status bar after rendering a sheet layer viewport), it turns out that if you're using a Renderworks background render style and a hidden line foreground render, at the end it'll only display the time of the hidden line component. For example, I just rendered a VP which took about 10 minutes to render, but the render time displayed at the end said 8 seconds (which is how long it took to compute the hidden line overlay).
It should instead display a total time, or only the time for the background render component.
1 answer to this question
Integrating this into the existing request for the render time to be easier to check after the fact. Currently its only in the message bar with the viewport selected and once you click away or change something, its gone permanently.
The fact that it resets for various phases I actually consider a bug, will file that separately.
