digitalcarbon Posted January 5, 2016 Share Posted January 5, 2016 tried doing Marionette Tutorial - Part 2 - Math and Wrappers what am i doing wrong? https://youtu.be/LBFmvT452fs Quote Link to comment
DomC Posted January 5, 2016 Share Posted January 5, 2016 Hi This file is running properly on my mac (Wrap). I Suppose there could be a Problem with the File Name, File Path, Vectorworks Installation Path or the User Settings (User/Library/Application Support/Vectorworks /2016 /PlugIns) try out deleting the marionette folder here. Hope that works ... Mac OSX 10.10.5 i7 Quote Link to comment
AlanW Posted January 5, 2016 Share Posted January 5, 2016 Hi running ok in PC as an object. Quote Link to comment
digitalcarbon Posted January 5, 2016 Author Share Posted January 5, 2016 "try out deleting the marionette folder here" what? Quote Link to comment
digitalcarbon Posted January 5, 2016 Author Share Posted January 5, 2016 (edited) "try out deleting the marionette folder here" what? and do what with it? how do i restore? Edited January 5, 2016 by digitalmechanics Quote Link to comment
Vectorworks, Inc Employee Vectorworks - Admin Posted January 5, 2016 Vectorworks, Inc Employee Share Posted January 5, 2016 IF you shut down Vectorworks, you can then go to the user library folder: User/Library/Application Support/Vectorworks /2016 And in the Plugins folder, there are subfolders for many tools, one of which is Marionette. I normally don't walk users to these itemized folders since so much else can also be important to clean out (we normally do the whole 2016 folder when cleaning preferences) but deleting or temporarily relocating the Marionette folder from within plugins then launching Vectorworks again effectively resets just that plugin for your installation of Vectorworks. Its a more surgical preference reset, less disruptive but also less likely to work. If you just want to test it out, just keep your copy of the Marionette folder on your desktop and simply replace it in the user folder location after testing. Quote Link to comment
Marionette Maven Marissa Farrell Posted January 5, 2016 Marionette Maven Share Posted January 5, 2016 @digitalmechanics, Assuming you know where your 2016 User Folder is, there is a folder in there called "Plug-ins" and inside of that "Marionette." Delete this "Marionette" folder and restart Vectorworks. Does the issue persist after that? Quote Link to comment
digitalcarbon Posted January 5, 2016 Author Share Posted January 5, 2016 https://youtu.be/w9dR9JpWN_4 still not working Quote Link to comment
Mark Flamer Posted January 5, 2016 Share Posted January 5, 2016 Can you take a look inside Marionette.py at that path and tell me what's inside? There was a problem a while back with this file ending up empty. Thanks, my apologies for the trouble. Quote Link to comment
Hippocode Posted January 5, 2016 Share Posted January 5, 2016 Apparently there is a UUID collision between my custom plug-in and Marionette. That's what causing it. Will have it fixed tomorrow. Quote Link to comment
Mark Flamer Posted January 15, 2016 Share Posted January 15, 2016 What about digitalmechanics? Are you still not able to use Marionette? Quote Link to comment
