The Cantor Posted January 4, 2016 Share Posted January 4, 2016 Very frustrated. Only allows ground support. VW 2016 on new Imac 27inch. Any ideas? Quote Link to comment
The Cantor Posted January 4, 2016 Author Share Posted January 4, 2016 It will work, but I have to close and reopen Vectorworks. This is taking a lot of time and very frustrating. Hope someone checks into the issue. Quote Link to comment
Vectorworks, Inc Employee PVA - Admin Posted January 4, 2016 Vectorworks, Inc Employee Share Posted January 4, 2016 I am able to select the Rigged configuration, did you create this Blended Screen new in 2016 or did it come from a previous version? Also: You have to select the Blended Projector and then change whether its Rigged or Screen Center or what have you in the Vertical Position field, not from the screen itself for projectors that were already inserted. Quote Link to comment
The Cantor Posted January 4, 2016 Author Share Posted January 4, 2016 Thanks. Changing in projectors makes sense. Quote Link to comment
Vectorworks, Inc Employee PVA - Admin Posted January 5, 2016 Vectorworks, Inc Employee Share Posted January 5, 2016 Looks like this shouldn't be required however. For now go ahead and select the projectors to change them, but a fix should be going in that will alter this behavior to something more friendly. Quote Link to comment
