DomC
Translate Values to Dims
Hi
What to do, if Input Values from "non-Dim-Nodes" deliver wrong dimension values?
It could be horrible just to multiply lists/tuples, point values etc. by factor.
Attached Node can help. It calculates every value of list up to double nested lists by the unit factor of the document. This node just works but the code inside could look ugly to a programmer. But as yet I did not found anything better than that.
How it works:
The Node has a Popup. With that popup you can set the input units. And get output values in the document units.
Dom
Edited by DomC
