AlanW Posted December 26, 2015 Share Posted December 26, 2015 Hi, Does this convert a text string into polygon shapes matching the text? Cant seem to get a text output, was expecting a poly text shape that I could extrude. Quote Link to comment
Kevin McAllister Posted December 26, 2015 Share Posted December 26, 2015 Alan, It needs to be wired like this. The String node is only a variable. You need to create the text object and then pass it to the Poly to Group node. This generates a grouped text object and a group of polygons stacked on top of each other. There is some sort of bug here though. The converted group of polygons doesn't appear initially though you can see it exists in the OIP. If you change the view it will appear after the fact. Kevin Quote Link to comment
AlanW Posted December 27, 2015 Author Share Posted December 27, 2015 (edited) Thanks Kevin, Can now extrude text along path. Edited December 27, 2015 by Alan Woodwell Quote Link to comment
CarlJdP Posted January 5, 2016 Share Posted January 5, 2016 ..convert a text string into polygon shapes matching the text? ..was expecting a poly text shape that I could extrude. How do I convert italicized text into polygons? I can'y seem to get this done from the traditional menus. It does convert, but to the non-italicized version of the text How do I solve this without having to trace the text manually? Quote Link to comment
AlanW Posted January 5, 2016 Author Share Posted January 5, 2016 Hi, it doesn't seem to work, I have noted to change only the first 3 letters and by placing a 2 in the bottom it should run italics, It does if you remove the delete but it is only the text and not polys. When you run this first no text shows up until you hit 5 (top plan) or a 3d key. Something to play with. Quote Link to comment
Marionette Maven Marissa Farrell Posted January 5, 2016 Marionette Maven Share Posted January 5, 2016 Hi CarlJdP and Alan! Marionette uses mostly the same functions that the software uses when you use menu commands/tools/etc. Since the italics are lost using only the menu command, I don't believe we will have a solution for Marionette until that is looked into. I'm not sure if there's another solution for this, but at least with Marionette, I can't think of a way. Marissa Quote Link to comment
