ahedley
vs.UnDoOff , vs.Redraw, vs.DselectAll
Hello,
Does anybody know if the functions; vs.UnDoOff , vs.Redraw, vs.DselectAll work in python and if so how do they work?
Adrian
These should all work. Don't forget that in Python, you need to pass empty arguments to run a command:
vs.DSelectAll()
Otherwise, you are just stating a reference to the function definition.
Also, Python is case sensitive. In your examples, the capitalization doesn't match the function reference.
HTH,
Josh
Well that was embarrassing. I was trying to convert an old test script to python and just assumed the function was spelt correctly, I just added vs. to beginning of function. My fault though for not checking the function reference properly.
Changed the spelling and things are working okay.
Thanks Josh,
Adrian
