ScottBFM Posted December 21, 2015 Share Posted December 21, 2015 I posted erroneously in General Discussion- looking for nodes to arrange/distribute/align. Quote Link to comment
Marionette Maven Marissa Farrell Posted December 21, 2015 Marionette Maven Share Posted December 21, 2015 @ScottBFM A while back I created nodes to move front/back/forward/backward, but they proved to be unreliable in a Marionette network. This is being looked into, but for now it doesn't seem like the control is available. I will keep this thread updated if any progress is made. As for distribute/align nodes, I have not yet began creating them, but I can certainly move it up on my list! If I'm able to produce anything that will reliably work, I will share it here. Quote Link to comment
nplache Posted January 14, 2016 Share Posted January 14, 2016 @Marissa Did you ever get anywhere with editing the "stacking order" of 2D objects created using marionette? (ie. moving objects front/forward/back/backward). I am battling with trying to get my text to sit on top of objects. Logically the last created object/text nodes should be on top but that doesn't seem to be the case. Would love a tool like "list" that allows you to plug in all your 2D objects and set their relative stacking Quote Link to comment
Marionette Maven Marissa Farrell Posted January 14, 2016 Marionette Maven Share Posted January 14, 2016 My most recent understanding is as follows: In an unwrapped Marionette script, the outcome of the stacking order continues to vary. This, I believe, is because when the script is compiled, there are some variables as to which nodes get run first, which I guess somehow messes up the stacking order. I cannot get a consistent and correct result using an unwrapped network. On the other hand, if you were to create a network, wrap it, and convert it to a Marionette Object, it appears as though the results are (at least for my testing purposes) always correct, as long as you define the stacking order at the end of the network. There is another thread that discusses these cases here, and Stephen has posted a file that has stacking order nodes towards the bottom. Once we figure out a way to handle the unwrapped network case, I'll try to get a good node file together and start a new topic of best use cases. I'm just not sure how long it will be until things are all in order. Quote Link to comment
nplache Posted January 16, 2016 Share Posted January 16, 2016 Thank you Marissa, these nodes work perfectly for my application. Quote Link to comment
EmilyArch Posted April 13, 2021 Share Posted April 13, 2021 Since this thread was last active, the link to to other thread containing the stacking order nodes has moved. Can anyone post a link to its new location? Thank you! Quote Link to comment
m.graf Posted April 17, 2021 Share Posted April 17, 2021 (edited) maybe this process is helpful... (also works without the <obj> node at the very end of a Marionette script, "scriptlines" can also be used as input) greatings M.Graf List Forward.vwx Edited April 17, 2021 by m.graf 1 Quote Link to comment
