At the moment an EAP converts the 2d drawn path into a nurbs-curve.
If that path is for example a rounded rectangle with a wrong radius on the corners you have to go into the object and redraw the rounded rectangel, not the most efficient way.
Two wishes:
1 - It would be great if planar wasn't converted to a nurbs curve.
Editing would be much faster this way.
2 - It would be great if the planar object for the path of the EAP were still editable in the OIP of the EAP.
Then it would be very easy to change the radius from a circle or the size of a rectangle without having to go in the EAP and redraw the path.
Two wishes:
Edited by Bas VellekoopShare this post
