GioPet
Cannot concatenate '&' ampersand in a string
I have found no way to resolve concatenation with '&' symbol, as it is ignored in the concatenation by both vs.AlrtDialog(vs.Concat()) and +
I have also tried the folloinwing:
amp = str.replace('&', '%26')
but no success.
any suggestion?
g
Have you tried escaping it? like '\&' + 'The rest of the string.' I have never had this, so I don't know if that's the issue here.
TIP: In Python, it's better/easier/more readable to use string format:
'This is my string: %s & %s' % ('My String', MyObject)
Where %s will be replaced by the string representation of the things inside the tuple.
Hi Dieter,
yes I tried that..
What turned out is that the & was actually concatenated in the string, but for some reason vs.AlrtDialog does not display it.
as I was using vs.AlrtDialog to check the string, it took me a while to figure out that actually & was there..
and thanks once more for your TIP, it's all very appreciated as I've still got so much to learn about Python!
G
Hi Dieter,
yes, I have tried vs.Chr(38) but it behaves in the same way:
The following displays correctly:
amp = vs.Chr(38)
vs.AlrtDialog(vs.Concat('ampersand = ', amp))
but when i use concatenation (either vs.Concat or python native +) AlrtDialog doesn't display the ampersand.
Bu then I used the concatenated string to make a http call I realised that all my ampersand were there as expected...
Giovanni,
It's been 5 months, and you may already have the answer, but for those that don't...
This is not a Python problem, but rather a quirk of the AlrtDialog() call, and possibly its Modern Dialog underpinnings.
Use two ampersands '&&' to show a single ampersand in an Alert Dialog string.
Use a single ampersand '&' in Message() command strings and in normal string use.
This holds true for both Python and VectorScript when using AlrtDialog().
Examples:
1)
vs.AlrtDialog('Watch out for Alligators && Snakes!!!')
vs.Message('Good luck avoiding Death & Taxes!!!')
2)
forAlrt = True
S = "Your Appetizer: {} {} {}".format('Cheese', '&&' if forAlrt else '&' , 'Crackers')
vs.AlrtDialog(S)
forAlrt = False
vs.Message(S)
HTH,
Raymond
