calsan
Layer name wildcard
I'm trying to find objects in layers whose name contains (for example) "250"
Why does this work for classes:
SelectObj(C='*250*');
but wildcard search doesn't work for layers:
SelectObj(L='*250*');
:confused:
I've wondered that too! I think it works with almost everything except layers.
Gotta be a bug.
mk
I wonder if there is an alternative routine to find by layer name?
I tried this and it doesn't work either...
PROCEDURE PickLayer250;
PROCEDURE SelectThem(h :HANDLE);
BEGIN
SetSelect(h);
END;
BEGIN
ForEachObject(SelectThem, L='*250*');
END;
RUN (PickLayer250);
I wonder if you could use the Pos function. If it returns something other than 0, then the substring is present in the layer name.
Seems like a hack, but it might work.
mk
:confused:
Probably because classes and layers are in another internal list. Layers have their own internal list, classes and all other objects are in the 'main' object list.
What you could do is first find all layers, filter out those that doesn't fit your search criteria, then create your search criteria based on that and then do the selection. I know this will be more work...
