joey altalef Posted December 5, 2015 Share Posted December 5, 2015 Hi everyone I've been trying to export to DWG a set of plans and I can not get my Dimensions to be exported correctly. We use dual view in our dimensions as seen in the file attached. After exporting and opening it on Autocad we will see only the primary value and never the second one. Is there a way to make this work? thanks! Im using V.2016 Quote Link to comment
bcd Posted December 5, 2015 Share Posted December 5, 2015 Probably the only way is to select the dimensions and Cmd-K (convert to group) this way you will retain the look of your dual dimensions but not the functionality. Quote Link to comment
