Possible bug in 2016 sp2?
kdelvo
Hello All,
I have been working on some plots on my laptop using VW2016 sp1 w/RW.
Installed the new 2016 sp2 on my home machine and noticed that in my rigging plot the hoist dims have no fill behind text. There is nothing I can do to place a white fill behind the hoist dims so the numbers are readable over grayed out truss layer underneath them.
As a test, I saved what I had and re-opened the files on my laptop running 2016 sp1.
and the text fill shows up.
Seems to be an issue with Service Pack 2...?
Has anyone else seen this?
Ken
VW2016, Spotlight, Renderworks, Service Pack 1 & 2
15" MacBook Pro, Retina, OSX 10.11.1
really old 27" iMac, OSX 10.11.1
I am unable to replicate this in a new file here in 2016 SP2. Currently in my test file I am able to just select the Hoist object and changing its Fill in the Attributes palette to None removes the dimension fills.
if you create a new blank document and add Hoist objects, do they behave the same way?
Jim,
Thanks for the rapid response.
As a test I created a new Spotlight document on my iMac running Sp2.
Added 2 Trusses and 6 Hoists. I did not adjust any classes or layers.
Just threw it all on a design layer. No fill on Hoist text.
Then did the same procedure on my Macbook running Sp1
All the hoists came in with fill behind the text.
Strange...
I also compared all Prefs & settings between the 2 programs
everything is the same.
Thanks,
Ken
