Drag dimensions bug
I have a detail with 3 dimensions. Whichever of these three I choose, when I attempt to drag to increase the offset or change the endpoints, the correct dimension is selected and can be modified in the OIP, but when I attempt to change that dimension by dragging, the first dimension created is is moved instead. I cannot modify the other two by dragging. Is this a known bug? Is this an artifact of parametrics (no parametric constraints are showing)? If so, parametrics is not working as it should.
It gets worse. I added a 4th dimension at right angles. Now the problem has shifted to focus on this dimension. What is worse, I cannot undo an action when this bug asserts.
Okay - turned off "associate dimensions" in document preferences, and things work properly. This option does not appear to work in a useful way, given the above behavior.
[ 04-21-2003, 12:57 PM: Message edited by: P Retondo ]
