P Retondo Posted April 21, 2003 Share Posted April 21, 2003 Now I'm getting this bug with some dimensions, even with the "associate dimensions" preference turned off. What is known, if anything, about this problem? Quote Link to comment
P Retondo Posted April 22, 2003 Author Share Posted April 22, 2003 I have a detail with 3 dimensions. Whichever of these three I choose, when I attempt to drag to increase the offset or change the endpoints, the correct dimension is selected and can be modified in the OIP, but when I attempt to change that dimension by dragging, the first dimension created is is moved instead. I cannot modify the other two by dragging. Is this a known bug? Is this an artifact of parametrics (no parametric constraints are showing)? If so, parametrics is not working as it should. It gets worse. I added a 4th dimension at right angles. Now the problem has shifted to focus on this dimension. What is worse, I cannot undo an action when this bug asserts. Okay - turned off "associate dimensions" in document preferences, and things work properly. This option does not appear to work in a useful way, given the above behavior. [ 04-21-2003, 12:57 PM: Message edited by: P Retondo ] Quote Link to comment
P Retondo Posted April 22, 2003 Author Share Posted April 22, 2003 When I closed and re-opened VectorWorks, the problem with these dimensions went away. Quote Link to comment
CipesDesign Posted April 22, 2003 Share Posted April 22, 2003 Peter, Yeah, I have a problem with my data display bar changing to all angle instead of dimensions. Quitting & restarting fixes it, but some days it might happen two or three times. These both sound like bugs and probably should be submitted. Peter Quote Link to comment
