Python Examples on DevWiki
twk
Greetings All,
Just read through the code for the sample python PIO's on the DevWiki, just noticed that most function calls were passing variables into it after initialising it first to '0' or an empty string.
global paramName, paramHandle, paramRecHandle, wallHandle
ok, paramName, paramHandle, paramRecHandle, wallHandle = vs.GetCustomObjectInfo( paramName, paramHandle, paramRecHandle, wallHandle )
From 'PythonSample_ObjectPt3'.
Why are variables being passed into the vs.GetCustomObjectInfo function? Shouldn't it be written like this:
ok, paramName, paramHandle, paramRecHandle, wallHandle = vs.GetCustomObjectInfo()
Is the first method the correct one?
Thanks
Tui
Oh ok cool, thanks Dieter.
Do you know what this part of the example code does? :
if paramHandle == 0:
       paramName = 'PythonSample_ObjectPt3'
Is that checking to see if there is no handle to the PIO object to force a PIO name? What is the benefit of doing this?
Thanks
Tui
Thanks
Tui
Lol, it doesn't do anything.... as paramName isn't used anywhere further in the script. So it can be removed. The example scripts aren't all that great you know. I get the feeling they were made by people that are just starting out with Python.
