calsan Posted November 25, 2015 Share Posted November 25, 2015 Help needed please! :confused: I would like a script to replace all object fill patterns in a 2d drawing with a fill colour using vectorscript. Can anyone help with this? For example, replace all instances of fill pattern #4 with fill colour #1826. Thanks for any help. Quote Link to comment
Hippocode Posted November 25, 2015 Share Posted November 25, 2015 (edited) Just create an empty drawing with 2 objects; One with attributes by class and one forced attributes based on a fill. Export to vectorscript and tada! This will give you all you need to "change" the fill. Next, all you need is a foreach loop with criteria, there are a lot of existing topics on how to use those. Edited November 25, 2015 by Hippocode Quote Link to comment
Dieter @ DWorks Posted November 25, 2015 Share Posted November 25, 2015 Just use ForEach... with Criteria, should be simple. Be aware that you can check out developer.vectorworks.net to see the function reference. Quote Link to comment
calsan Posted December 9, 2015 Author Share Posted December 9, 2015 Well, still struggling. I have found out this much: This script pops up the object attributes for any object with fill pattern 3 and allows manual selection of the fill attribute. EditProperties(INGROUP & INVIEWPORT & (FP=3)); This script sets the fill background colour of any selected object to colour 1236: Procedure Filler; FUNCTION fillObj(h:HANDLE) :BOOLEAN; Begin SetFPat(h,1); SetFillBack(h,1236); End; BEGIN ForEachObjectInLayer(FillObj,2,0,4); END; RUN(Filler); No idea how to link the two. Actually, I haven't found much in the way of reference material. Vectorlab.info doesn't exist anymore and the script reference just provides a list of functions.... Quote Link to comment
calsan Posted December 9, 2015 Author Share Posted December 9, 2015 This works, but doesn't update items in groups... Procedure Filler; FUNCTION fillObj(h:HANDLE) :BOOLEAN; Begin SetFPat(h,1); SetFillBack(h,1236); End; BEGIN DSelectAll; SelectObj(INSYMBOL & INOBJECT & INVIEWPORT & (FP=3)); ForEachObjectInLayer(FillObj,2,2,1); END; RUN(Filler); Quote Link to comment
Hippocode Posted December 9, 2015 Share Posted December 9, 2015 You need to reset the objects you changed for them to reappear with the new attributes. Quote Link to comment
Dieter @ DWorks Posted December 9, 2015 Share Posted December 9, 2015 (edited) I guess you want to set the fill for all the objects in your search criteria? Then you could do the following: FUNCTION filler(): FUNCTION fillObj(h: HANDLE): BOOLEAN; BEGIN SetFPat(h, 1); SetFillBack(h, 1236); END; BEGIN ForEachObject(fillObj,'(INSYMBOL & INOBJECT & INVIEWPORT & (FP=3))'); END; RUN(filler); It's better to not play with the selection, as this can confuse users, as after your script, the selection will be changed.... Edited December 9, 2015 by Dieter @ DWorks Quote Link to comment
Dieter @ DWorks Posted December 9, 2015 Share Posted December 9, 2015 You need to reset the objects you changed for them to reappear with the new attributes. That's not entirely true.... Quote Link to comment
Hippocode Posted December 9, 2015 Share Posted December 9, 2015 You need to reset the objects you changed for them to reappear with the new attributes. That's not entirely true.... Well behavior is different between object types and even Vectorworks versions. I just always do it to make sure it's properly reset. Quote Link to comment
calsan Posted December 9, 2015 Author Share Posted December 9, 2015 Hi Thanks for the help - but I can't get this line to compile: BEGIN ForEachObject(fillObj,'(INSYMBOL & INOBJECT & INVIEWPORT & (FP=3))'); END; I tried with and without the '' but it just pops up a script error. I'm sorry, I also don't know how to reset objects! Quote Link to comment
Dieter @ DWorks Posted December 9, 2015 Share Posted December 9, 2015 Hi Thanks for the help - but I can't get this line to compile: BEGIN ForEachObject(fillObj,'(INSYMBOL & INOBJECT & INVIEWPORT & (FP=3))'); END; I tried with and without the '' but it just pops up a script error. I'm sorry, I also don't know how to reset objects! Can you paste the script error you get? I typed this out of my head, probably some syntax error.... I don't use this that often. Quote Link to comment
calsan Posted December 10, 2015 Author Share Posted December 10, 2015 This is the error output with '' in place: Line #1: FUNCTION filler(): | { Error: Expected beginning of a statement. } | { Error: Identifier not declared. } Line #3: FUNCTION fillObj(h: HANDLE): BOOLEAN; | { Error: Identifier not declared. } | { Error: Identifier not declared. } Line #6: SetFPat(h, 1); | { Error: Identifier not declared. } | { Error: Expected a string. } | { Error: Expected a handle. } | { Error: Expected , } | { Error: Expected a string. } | { Error: Expected ) } | { Error: Did not expect this after end of statement - missing ;? } Line #7: SetFillBack(h, 1236); | { Error: Expected END } | { Error: Identifier not declared. } | { Error: Expected a string. } | { Error: Expected a handle. } | { Error: Expected , } | { Error: Expected a string. } | { Warning: Expected a longint or integer expression. } | { Error: Expected , } | { Error: Expected a string. } | { Warning: Expected a longint or integer expression. } | { Error: Expected , } | { Error: Expected a string. } | { Warning: Expected a longint or integer expression. } | { Error: Expected ) } | { Error: Did not expect this after end of statement - missing ;? } Quote Link to comment
calsan Posted December 10, 2015 Author Share Posted December 10, 2015 This is with the '' removed Line #1: FUNCTION filler(): | { Error: Expected beginning of a statement. } | { Error: Identifier not declared. } Line #3: FUNCTION fillObj(h: HANDLE): BOOLEAN; | { Error: Identifier not declared. } | { Error: Identifier not declared. } Line #6: SetFPat(h, 1); | { Error: Identifier not declared. } | { Error: Expected a string. } | { Error: Expected a handle. } | { Error: Expected , } | { Error: Expected a string. } | { Error: Expected ) } | { Error: Did not expect this after end of statement - missing ;? } Line #7: SetFillBack(h, 1236); | { Error: Expected END } | { Error: Identifier not declared. } | { Error: Expected a string. } | { Error: Expected a handle. } | { Error: Expected , } | { Error: Expected a string. } | { Warning: Expected a longint or integer expression. } | { Error: Expected , } | { Error: Expected a string. } | { Warning: Expected a longint or integer expression. } | { Error: Expected , } | { Error: Expected a string. } | { Warning: Expected a longint or integer expression. } | { Error: Expected ) } | { Error: Did not expect this after end of statement - missing ;? } Quote Link to comment
calsan Posted December 10, 2015 Author Share Posted December 10, 2015 On a tangent... This forum needs a 'like post' option... Would be nice to give a like to someone who's trying to help you out of a hole. Quote Link to comment
Dieter @ DWorks Posted December 10, 2015 Share Posted December 10, 2015 (edited) FUNCTION filler(): should be PROCEDURE filler; , as it doesn't return anything. When an error occurs, you always get a long list of errors, but you have to solve them in the order they are given, because lower errors are mostly because of errors happening before it. So fixing the first could be solving all the others. Edited December 10, 2015 by Dieter @ DWorks Quote Link to comment
calsan Posted December 10, 2015 Author Share Posted December 10, 2015 This is the script now. Procedure filler; Function fillObj(h:HANDLE):BOOLEAN; BEGIN SetFPat(h, 1); SetFillBack(h, 1236); END; BEGIN ForEachObject(fillObj,(INSYMBOL & INOBJECT & INVIEWPORT & (FP=3))); END; RUN(filler); Quote Link to comment
calsan Posted December 10, 2015 Author Share Posted December 10, 2015 And this is the error: Line #8: ForEachObject(fillObj,(INSYMBOL & INOBJECT & INVIEWPORT & (FP=3))); | { Error: Expected a procedure that accepts one handle argument. } Line #10: RUN(filler); | { Error: Expected a RUN statement at the end of the script } Quote Link to comment
twk Posted December 10, 2015 Share Posted December 10, 2015 I believe the fillobj Function has to be a procedure that accepts a single handle argument. PROCEDURE fillObj(h:HANDLE); BEGIN SetFPat(h, 1); SetFillBack(h, 1236); END; Quote Link to comment
calsan Posted December 10, 2015 Author Share Posted December 10, 2015 Procedure filler; PROCEDURE fillObj(h:HANDLE); BEGIN SetFPat(h, 1); SetFillBack(h, 1236); END; BEGIN ForEachObject(fillObj,(INSYMBOL & INGROUP & INOBJECT & INVIEWPORT & (FP=3))); END; RUN(filler); This works!!!!!!!! Happy Happy Joy Joy Many thanks to Dieter @ DWorks and twk. I hope the above code will be of use to someone reading this in the future. Quote Link to comment
calsan Posted December 10, 2015 Author Share Posted December 10, 2015 Have modified the script to replace on multiple patterns to fills. Posting as may be of use to someone. Quote Link to comment
calsan Posted December 10, 2015 Author Share Posted December 10, 2015 Procedure PatternsSwapToFill; PROCEDURE fillObj1(h:HANDLE); BEGIN SetFPat(h, 1); SetFillBack(h, 1236); {Fill 1 - Type the desired fill colour # here} END; PROCEDURE fillObj2(h:HANDLE); BEGIN SetFPat(h, 1); SetFillBack(h, 1237); {Fill 2 - Type the desired fill colour # here} END; PROCEDURE fillObj3(h:HANDLE); BEGIN SetFPat(h, 1); SetFillBack(h, 1238); {Fill 3 - Type the desired fill colour # here} END; PROCEDURE fillObj4(h:HANDLE); BEGIN SetFPat(h, 1); SetFillBack(h, 1239); {Fill 4 - Type the desired fill colour # here} END; PROCEDURE fillObj5(h:HANDLE); BEGIN SetFPat(h, 1); SetFillBack(h, 1240); {Fill 5 - Type the desired fill colour # here} END; PROCEDURE fillObj6(h:HANDLE); BEGIN SetFPat(h, 1); SetFillBack(h, 1241); {Fill 6 - Type the desired fill colour # here} END; BEGIN ForEachObject(fillObj1,(INSYMBOL & INGROUP & INOBJECT & INVIEWPORT & (FP=3))); {Type the original pattern 1 # here} ForEachObject(fillObj2,(INSYMBOL & INGROUP & INOBJECT & INVIEWPORT & (FP=4))); {Type the original pattern 2 # here} ForEachObject(fillObj3,(INSYMBOL & INGROUP & INOBJECT & INVIEWPORT & (FP=5))); {Type the original pattern 3 # here} ForEachObject(fillObj4,(INSYMBOL & INGROUP & INOBJECT & INVIEWPORT & (FP=6))); {Type the original pattern 4 # here} ForEachObject(fillObj5,(INSYMBOL & INGROUP & INOBJECT & INVIEWPORT & (FP=7))); {Type the original pattern 5 # here} ForEachObject(fillObj6,(INSYMBOL & INGROUP & INOBJECT & INVIEWPORT & (FP=8))); {Type the original pattern 6 # here} END; RUN(PatternsSwapToFill); Quote Link to comment
calsan Posted December 10, 2015 Author Share Posted December 10, 2015 I found out the fill numbers are unreliable, as they have changed between vectorworks versions. More reliable than fill numbers is to use 24bit RGB values. Get the RGB Value by hovering over the fill in the attirbutes palette. Multiply each RGB value by 256 i.e. Grey of RGB value (221, 221, 221) becomes (56576, 56576, 56576) Below is amended 24bit RGB script. Quote Link to comment
calsan Posted December 10, 2015 Author Share Posted December 10, 2015 Procedure PatternsSwapToFill; PROCEDURE fillObj1(h:HANDLE); BEGIN SetFPat(h, 1); SetFillBack(h,21760,21760,21760); {Fill 1 - Type the desired fill colour # here} END; PROCEDURE fillObj2(h:HANDLE); BEGIN SetFPat(h, 1); SetFillBack(h, 34816,34816,34816); {Fill 2 - Type the desired fill colour # here} END; PROCEDURE fillObj3(h:HANDLE); BEGIN SetFPat(h, 1); SetFillBack(h, 43520,43520,43520); {Fill 3 - Type the desired fill colour # here} END; PROCEDURE fillObj4(h:HANDLE); BEGIN SetFPat(h, 1); SetFillBack(h, 49152,49152,49152); {Fill 4 - Type the desired fill colour # here} END; PROCEDURE fillObj5(h:HANDLE); BEGIN SetFPat(h, 1); SetFillBack(h, 56576,56576,56576); {Fill 5 - Type the desired fill colour # here} END; PROCEDURE fillObj6(h:HANDLE); BEGIN SetFPat(h, 1); SetFillBack(h, 60928,60928,60928); {Fill 6 - Type the desired fill colour # here} END; BEGIN ForEachObject(fillObj1,(INSYMBOL & INGROUP & INOBJECT & INVIEWPORT & (FP=3))); {Type the original pattern 1 # here} ForEachObject(fillObj2,(INSYMBOL & INGROUP & INOBJECT & INVIEWPORT & (FP=4))); {Type the original pattern 2 # here} ForEachObject(fillObj3,(INSYMBOL & INGROUP & INOBJECT & INVIEWPORT & (FP=5))); {Type the original pattern 3 # here} ForEachObject(fillObj4,(INSYMBOL & INGROUP & INOBJECT & INVIEWPORT & (FP=6))); {Type the original pattern 4 # here} ForEachObject(fillObj5,(INSYMBOL & INGROUP & INOBJECT & INVIEWPORT & (FP=7))); {Type the original pattern 5 # here} ForEachObject(fillObj6,(INSYMBOL & INGROUP & INOBJECT & INVIEWPORT & (FP=8))); {Type the original pattern 6 # here} END; RUN(PatternsSwapToFill); Quote Link to comment
calsan Posted December 10, 2015 Author Share Posted December 10, 2015 Instructions to install the above script into a menu in your workspace: Create the plugin: Select menu item: Tools / Plug-ins / Plug-in Manager... Custom Plug-ins Tab - click "New..." Name the script "Grey Patterns to Grey Fills" Select the option "Command" Click "OK" Click "Edit Script..." Paste the script text copied from the above field Click "OK" Click "Close" Edit your workspace: Find the command "Grey Patterns to Grey Fills" under miscellaneous Drag it under the menu "New" (or your preferred menu location. This will now be available at all times under the New menu Quote Link to comment
Dieter @ DWorks Posted December 10, 2015 Share Posted December 10, 2015 This works!!!!!!!! Happy Happy Joy Joy Many thanks to Dieter @ DWorks and twk. Always happy to help out. Quote Link to comment
