DomC
Exhibition Wall
Hi there
A Marionette Path Object for rectangular exhibition walls. Use second reshape methode to edit path. The objects uses symbols for profiles and walls. So you are able to control wall thickness, classes and material over the symbol definition. Make sure the symbols are content of your document. Offcut or start points of the duplication are controlled inside the marionette script. There are some custom nodes used like: duplicate array between points, insert symbol and change wall length
Edited by DomC
