Marissa Farrell
Objects - Lights
Hi Everyone,
Attached is a folder that includes light nodes, since currently Vectorworks does not ship with them.
Let me know what you think and I can continue to expand upon them!
Since the default library does not have an RGB input node, you can use the "Vec3" node to input RGB values. These values range between 0-65535.
Feedback is welcome and appreciated!
-Marissa
A note on using light nodes in a Marionette Object:
I have had mixed results on whether or not the light would display as 'on' while rendering in renderworks - where you would REALLY want it most.
If you were to just use the nodes in a network and produce something, they should render in all modes - again, the Marionette OBJECT has been my only issue, and not even always.
I'm working to find a way around it, but I just wanted to share this knowledge before someone may ask about it.
Thanks!
Marissa
