AlanW Posted November 9, 2015 Share Posted November 9, 2015 I have a cabinet and If the width of the cabinet is >600 and <1200 have 2 equal doors, If <600mm then have only 1 door. What might the setup be for the script??? Quote Link to comment
DomC Posted November 9, 2015 Share Posted November 9, 2015 (edited) Hi Alan You can check if your value is from 600 to 1200 and returns a "True". That can be complicated if you have many if then statements or if maybe a specific combination of true or false should gives other results. If you produce many True and False "Answers" and if just one of them would be "False" the whole result is False (if >600 is true and >1200 is false and smartDoor is true etc. etc.) the answer still will be False (just one door as example) and for your example you can do it this way: Edited November 9, 2015 by DomC Quote Link to comment
benAU Posted November 10, 2015 Share Posted November 10, 2015 (edited) alternate network to resolve number of doors Edited November 10, 2015 by benAU Quote Link to comment
AlanW Posted November 10, 2015 Author Share Posted November 10, 2015 (edited) Ben, Thanks for this nice and clear explanation. So simple when you know how, but for me its all learning and loving it. By the way to upload hit the Reply and at the bottom of the page and you see file manager,Click on choose file, then add file and it uploads, (max 20MB) the once you done click done adding files and then submit post. If you don't see file manager you have started typing a response without hitting reply first Edited November 10, 2015 by Alan Woodwell Quote Link to comment
benAU Posted November 10, 2015 Share Posted November 10, 2015 Thanks Alan, worked our File Manager. Yes Marionette is annoyingly addictive. Someone made a comment a while back that productivity would dramatically decrease for a while as we all played with Marionette and Subdivision! I do however have a real application I can use Marionette for but it will take a while before I can make the network powerful enough to replace manual drafting. Now back to work! Quote Link to comment
