Pat Stanford 1,428 Posted November 6, 2015 This script was written based on a query in another forum: https://techboard.vectorworks.net/ubbthreads.php?ubb=showflat&Number=218975#Post218975 Procedure SymbolContentsToByClass; {If the selected object in a drawing is a symbol, it locates the} {symbol definition and converts all objects inside the definition} {to use the ByClass option for all attributes} {November 6, 2015} {© 2015, Pat Stanford pat@coviana.com} {Licensed under the GNU Lesser General Public License} {This has only been lightly tested. I recommend that you use this on a } {copy of your primary file. No warranty expressed or implied. Use at} {your own risk. Do not operate heavy machinery while using this script.} Var H1, H2, H3: Handle; SymDefName: String; Begin H1:=FSActLayer; If GetType(H1)=15 then Begin SymDefName:=GetSymName(H1); H2:=GetObject(SymDefName); H3:=FinSymDef(H2); While H3 <> Nil do Begin SetLSByClass(H3); SetLWByClass(H3); SetMarkerByClass(H3); SetOpacityByClass(H3); SetPenColorByClass(H3); SetFPatByClass(H3); SetFillColorByClass(H3); H3:=NextObj(H3); End; End; ResetObject(H1); RedrawAll; End; Run(SymbolContentsToByClass); Quote Share this post Link to post
Boh 436 Posted December 14, 2017 (edited) Just tried this and it works! Is it easy to change this script it's inverse? (i.e.Remove all "by-class" settings of objects in a symbol). Edited December 14, 2017 by Boh Quote Share this post Link to post
MullinRJ 203 Posted December 21, 2017 Boh, There may be a more elegant way to remove the Attributes-By-Class setting for selected objects, but I can't find it. I can only do it by removing each attribute individually. Here's a script to that effect. This will work on multiple selected symbols, but not on nested symbols. If a symbol definition contains other symbol instancess, they will not be affected. You will have to run this script on instances of each symbol you want to convert. You can place them in the drawing, select them all, then run the script once. After this script is run, you will not see any differences in the symbol's appearance. The objects inside will have the same attributes as the classes they are in. However, if you then change the appearance of a controlling class, these symbols will not follow the new class appearance since their contents no longer are set By-Class. I hope this is what you were looking for. Raymond Procedure SymbolContentsNotByClass; { If the selected objects in a drawing are symbols, this script locates } { each symbol definition and converts all objects inside the definition } { to REMOVE the SetByClass option for all attributes. } { 21 December 2017 - Raymond Mullin } { This has been less than lightly tested. Pat Stanford recommends you use } { this on a copy of your primary file. No warranty expressed or implied. } { Use at your own risk. Do not operate heavy machinery while using this script. } { I concur. } VAR SymH, H: Handle; B, visibility :Boolean; thickBasis, angul, Opacity, PenOp, FillOp :Integer; style, Red, Grn, Blu :Longint; size, wydth, thickness :Real; BEGIN SymH := FSActLayer; while (SymH <> Nil) do begin if (GetTypeN(SymH) = 15) then begin { if it is a Symbol } H := FinSymDef(GetObject(GetSymName(SymH))); while (H <> Nil) do begin SetLW(H, GetLW(H)); SetLSN(H, GetLSN(H)); GetPenFore(H, Red, Grn, Blu); SetPenFore(H, Red, Grn, Blu); GetPenBack(H, Red, Grn, Blu); SetPenBack(H, Red, Grn, Blu); SetFPat(H, GetFPat(H)); GetFillFore(H, Red, Grn, Blu); SetFillFore(H, Red, Grn, Blu); GetFillBack(H, Red, Grn, Blu); SetFillBack(H, Red, Grn, Blu); if GetObjBeginningMarker(H, style, angul, size, wydth, thickBasis, thickness, visibility) then B := SetObjBeginningMarker(H, style, angul, size, wydth, thickBasis, thickness, visibility); if GetObjEndMarker(H, style, angul, size, wydth, thickBasis, thickness, visibility) then B := SetObjEndMarker(H, style, angul, size, wydth, thickBasis, thickness, visibility); { For VW 2016 and earlier, use the following for Opacity: } GetOpacity(H, Opacity); SetOpacity(H, Opacity); { For VW 2017 and later, use the following for Opacity: } { if GetOpacityN(H, PenOp, FillOp) then B := SetOpacityN(H, PenOp, FillOp); } H := NextObj(H); end; { while (H <> Nil) } ResetObject(SymH); end; { if } SymH := NextSObj(SymH); end; { while (SymH <> Nil) } RedrawAll; END; Run(SymbolContentsNotByClass); Quote Share this post Link to post
Boh 436 Posted December 21, 2017 That is brilliant Raymond! Thank you. Perfect for me as I am sorting out my library of symbols so very useful. Quote Share this post Link to post
