AlanW Posted November 5, 2015 Share Posted November 5, 2015 (edited) Hi, If you are in a Marionette script the debug says you cant use it. Before wrapping it you can use to select a line but after you cant. How do you look at things?? Not knowing code also if an error shows up it might say line 300?? How would I see that line. Thanks Edited November 5, 2015 by Alan Woodwell Quote Link to comment
kerfboy Posted March 23, 2017 Share Posted March 23, 2017 Did you ever get an answer to this Alan? I am having similar issues. Not sure how to track down errors like SyntaxError: invalid syntax. When I click select node it closes the wrapper that contains all the scripts. Quote Link to comment
AlanW Posted March 24, 2017 Author Share Posted March 24, 2017 @kerfboy, This one not really but if you unhitch the network backward you should see where the error is. It you get a specific node to look at it can give you can usually see what the issue is. HTH. Either post the network or email it to me and I can have a look. Quote Link to comment
