kufuffin Posted November 3, 2015 Share Posted November 3, 2015 Hi, I'm trying to use the site modifier tool in contour & bezier vertex mode and each time I create a curved contour it immediately turns into a straight contour. It was working fine a moment ago. Can anyone suggest some troubleshooting tips? Thank you. Quote Link to comment
CipesDesign Posted November 3, 2015 Share Posted November 3, 2015 Not sure about the tool in that mode. But in case you didn't know, you can draw a Polyline with the polyline tool (or any shape) and then use the command: Objects from Shapes. This command can be very handy for many things, including site modifiers. Quote Link to comment
kufuffin Posted November 3, 2015 Author Share Posted November 3, 2015 Thanks for the response. Unfortunately it's turning all curved contours straight, including those that are created from a shape. Quote Link to comment
CipesDesign Posted November 3, 2015 Share Posted November 3, 2015 Oh yeah. Sorry. I believe (but not sure) that is how it's designed (which is basically wrong!). Perhaps you/we need to start with a very finely segmented poly to mimic a curve. And yes this has annoyed me a lot, but like so many imperfect things in VW's and in life, I try not to let it ruin my day... Not always successfully, but at least I try ;-) Quote Link to comment
J. Wallace Posted November 4, 2015 Share Posted November 4, 2015 Hi Kufuffin What version of VW are you using. It might be an idea to update your profile to include version and the computer your using. I just created a curved (closed) line and created objects from shape, site modifier...no problem. You may loose sight of it it the z value is lower than your model. Quote Link to comment
CipesDesign Posted November 4, 2015 Share Posted November 4, 2015 Hi JW, when you go to Top/Plan and look at the Proposed Contours, do they show as true curves?? I'm curious and don't have time to experiment until later. Quote Link to comment
Rossford Posted November 4, 2015 Share Posted November 4, 2015 Are you using 2016? And, trying to use the new "contour" mode? If prior to 2016, there are no 3D polylines, when you convert to 3D, they go to 3D polygons, but usually, if you drew a polyline curve, it had hundreds of vertices. I am wondering about 2016. I saw Jonathan Pickup use the contour mode in a webinar. It started straight, but he used the reshape tool to convert a few points to Bezier, which worked to visually round off his 3D contour line site modifier. So, try that. For me, it would be wonderful if they eliminated a few steps so 3D polygons could be drawn first. I looked into the 2016 help, which didn't cover it clearly. It would almost be too good to be true. It did mention that contour site modifiers are usually level, but can be drawn at a slope, if you specify it. That in itself may be a great improvement in drawing free form swales at whatever per cent you might want, over creating a bunch of smaller straight ones. I was actually going to experiment using the road tool to create curving swales, but this might do the trick even better, if it is what I think it is. Quote Link to comment
kufuffin Posted November 4, 2015 Author Share Posted November 4, 2015 I am using 2016 with the new contour mode. Thanks Rossford, your advice was very helpful! I tried using the reshape tool on the contour and when I hover over the vertex point a ghosted image of the curve I made appears in addition to the straight contour that vw is displaying. I just solved the issue, here it is: When you create the contour it asks what you want your 'Simplification tolerance' to be. 0 means it will not simplify the curve at all. I wasn't paying enough attention and was entering the elevation into that first parameter, so it thought I wanted to simplify 310'. Here is the definition from the VW website: "Enter a positive value to redefine the horizontal distance between the closest parts of two neighboring portions of the modifier. A longer distance simplifies the modifier polygon, reducing the number of source points that modify the site model. A shorter distance increases the number of source points that modify the site model. A value of 0 (zero) does not simplify the modifier." Quote Link to comment
