DomC Posted October 31, 2015 Share Posted October 31, 2015 Hi I just work on a script, that let us jump to the next saved view in alphabetical order. (I know Vectorworks Remote could do that) First Problem: Handle the saved views by script (I tried with ID, Parent etc. and failed). Thanks to Pat Standford (My Hero) which found a solution with vs.FIn3D :-) https://techboard.vectorworks.net/ubbthreads.php?ubb=showflat&Number=118441 Second Problem: The saved views are stored in the order they was created. Here Python scripting is showing one advantage. We can beatifully sort list with python. #Python code to create list h=vs.FIn3D(vs.GetObject('Darstellungen'))# International Version "saved views" views=[] while h != None: name=vs.GetName(h) views.append(name) h=vs.NextObj(h) views.sort() # Sorts the list alphabetically An extended Version. It maintains a Text Block inside the document which acts as a counter in the document. Because after execution the script can't remember the last saved view. Maybe there is a more smarter way by using a hidden record or something like this. I am not familiar with that. #Python code to create list, grab and change the named(Info Palette Data field) text block and call up the saved view h=vs.FIn3D(vs.GetObject('Darstellungen'))# International Version "saved views" views=[] while h != None: name=vs.GetName(h) views.append(name) h=vs.NextObj(h) views.sort() # Sorts the list alphabetically zähler=vs.GetObject('zähler') #Handle to the text block Darstellung=vs.GetText(zähler) #Read Text index=views.index(Darstellung) #Check on which index of the list (of the sorted list) this view is stored if index < len(views)-1: # -1 it's because len counts from 0 I think vs.SetText(zähler, views[index+1]) #Change the Text block to the next saved view vs.Message(index) if index+1 == len(views): vs.SetText(zähler, views[0]) #Starts from the beginning vs.ResetObject(zähler) vs.VRestore(Darstellung) #call saved View This hits on an idea to make a slide show, from save views. With an automatically delay. But this is tricky, because it seems to be a feature from scripts, that they do not regenerate views during the script execution. I tried out with a Dialog Box. That seems to work. But who want's to klick a away a Dialoge Box after every Slide. I tried to do this this way: import time h=vs.FIn3D(vs.GetObject('Darstellungen')) views=[] i=0 while h != None: name=vs.GetName(h) views.append(name) h=vs.NextObj(h) views.sort() length=len(views) def view(): for i in range(length): #vs.Message(str(views[i])) #time.sleep(0.5) #vs.SetZoom(100) #vs.SetZoom(50) #vs.ReDrawAll vs.VRestore(views[i]) #vs.Wait(1) return() view() Quote Link to comment
Dieter @ DWorks Posted November 4, 2015 Share Posted November 4, 2015 Hi, first of all, make it a menu command, that way you can store parameters like you can do with tools and objects. Each time it is run, you can store the last saved view in a parameter to get it back the next time. second, you could add the menu command to your context menu, and that could act like a next button, no? Or assign a shortcut to it. You'll have no dialog boxes, and the slideshow will just run, like a PowerPoint presentation, just not automatic, but a click or button press isn't that bad imho. Quote Link to comment
