  • 7
dancraig
Disappearing Title Block
Hey all,
Odd one: when I update the data in a title block, the title block disappears.
The Obj Info tab still has the settings for the title block showing, suggesting it's still there but not visible.
I'm not making any changes to the classes or formatting, just updating the data.
I've tried removing the title block completely and re-adding it, but the problem re-occurs.
Any help gratefully received.
Dan
Hello all,
@Kevin McAllister, I do not think that this is a problem with TBBs specifically, as there seems to be other objects disappearing too.
Are there any certain steps that are causing the TBBs to disappear 100% of the time? If so, could you share them so that we could investigate this?
Best Regards,
Nikolay Zhelyazkov
I've seen this on Sheet Layers also - it looks like it may be a drawing/zoom problem
My fix is to move the object and immediately undo.
Thanks for the followup!
Too early to tell. I've only had TBBs disappear in VW2020. Most of the other sheet layer issues seem to be resolved so far.
If I can find a reproducible version of this I will most definitely bug submit it. So far its been quite random.
Kevin
I often have TBB's disappear.  When I hover over them, I can seem them highlight.  If I grab them and pull them a bit, they come back.
On 5/23/2020 at 3:53 AM, andrewgreenwk@hotmail.com said:
Hi all i'm currently have this issue as well
Hi, i dont know when will this issue gonna resolved. What happened to me now is sometime the title block do not appear and sometime the title block is not at the correct position on sheet. What i did is open the page setup, and simply press enter without changing any setting and the title block will be good. It sort of refreshing the file memory, i dunno😅. Hope this helps.
Edited by Acip79
Title Block bars just disappeared on two separate sheets. VW 2020. This issue has been going on since 2014 apparently. 6 years ffs.
Yep.  Happening to me about 50% of the time I go to one of my Sheet Layers.  The Title Block seems to still be there, if you click on a part of it.  If I double-click, open and close the subsequent dialog box, the block appears again.  Keeps happening.  Multiple files,  VW2020 SP4.   Usually, when it happens, all of my sheets are affected.   So far, it still shows up when I Publish.   Amazing this is going on for 6 years.   What the hec??
I have switched to VW2020 last week and now the TBB keeps disappearing.
Ctrl+F does the trick indeed, but it is strange why it just disappears out of nothing.
I never had this with VW 2018
