dancraig Posted October 21, 2015 Share Posted October 21, 2015 Hey all, Odd one: when I update the data in a title block, the title block disappears. The Obj Info tab still has the settings for the title block showing, suggesting it's still there but not visible. I'm not making any changes to the classes or formatting, just updating the data. I've tried removing the title block completely and re-adding it, but the problem re-occurs. Any help gratefully received. Dan Quote Link to comment
0 bcd Posted October 21, 2015 Share Posted October 21, 2015 When I hear the word 'disappearing' I invariably think 'invisible class' As a starting point try turning on every class in the document (undo is our friend if you don't create a saved view first) Quote Link to comment
0 rDesign Posted October 21, 2015 Share Posted October 21, 2015 (edited) There was another thread about this recently, I don't know that it was ever resolved. Titleblocks Vanishing Edited October 20, 2016 by rDesign Quote Link to comment
0 dancraig Posted October 21, 2015 Author Share Posted October 21, 2015 Thanks both. I've tried playing around with it but no success. The odd thing for me is that I'm not changing classes to make it disappear - I'm updating a database. Maybe something to do with the classes embedded in the title block - will keep playing and report back. Quote Link to comment
0 rDesign Posted October 21, 2015 Share Posted October 21, 2015 The original poster in that other thread also said that all the classes were on: Two completely unrelated occurrences is starting to sound like a bug to me. Keep us posted - good luck. Quote Link to comment
0 dancraig Posted October 21, 2015 Author Share Posted October 21, 2015 A machine restart has cured the problem... still very odd. Will let you know if any re-occurrence. Dan Quote Link to comment
0 Vectorworks, Inc Employee PVA - Admin Posted October 21, 2015 Vectorworks, Inc Employee Share Posted October 21, 2015 Will let you know if any re-occurrence. Please! Quote Link to comment
0 AlanW Posted October 21, 2015 Share Posted October 21, 2015 I have recently found that when things dissapear you can still select then but appear transparent so I change then to another class that's on then back to the original class and they become visible again. Also if the roof wont turn off sometimes I found if you rotate it to 3d its gone but back to 2d it appears. I flip to 3d and turn the roof class on and off and then when you go back to 2d they are off. Strange behaviour. 1 Quote Link to comment
0 dancraig Posted October 25, 2015 Author Share Posted October 25, 2015 I haven't been able to make this bug (?) reoccur since my last posts for what it's worth... Quote Link to comment
0 Markus Barrera-Kolb Posted July 25, 2016 Share Posted July 25, 2016 I've had all of my sheet border objects and title blocks disappear from one of my current VW2016 files – I can see them when I query for them in a custom selection of worksheet database row, but I can't select them and I can't see them in the drawing. Not a class or class visibility issue, I've quadruple-checked that. Quote Link to comment
0 Josh NZ Posted July 25, 2016 Share Posted July 25, 2016 Ive had a similar issue when I renamed the base symbol that the title block uses. Didn't fully disappear but a very light grey text box shows up somewhere on the page advising that the titleblock can't use the symbol from memory. Quote Link to comment
0 Andy Broomell Posted July 28, 2016 Share Posted July 28, 2016 Today I witnessed a colleague's title block disappear when trying to edit it, as described above. It didn't appear to be a class issue (all were on), and it didn't appear to have anything to do with the Symbol's name or location in the Resource Browser (which would've been my first guess). The weird thing is the entire Sheet Border object disappears, not just the Title Block portion. Not sure what's happening... 1 Quote Link to comment
0 Markus Barrera-Kolb Posted July 28, 2016 Share Posted July 28, 2016 That's exactly right – the whole sheet border object disappears, and if it's anything like what we're experiencing, it'll still show up in the object count when you do a custom selection or run a database row in a worksheet... In one word: VEXING! Quote Link to comment
0 L0rriel Posted July 31, 2016 Share Posted July 31, 2016 I am experiencing the same issue. My custom title block vanishes on a regular basis, and did so in VW2015 as well. It is definitely not a classes issue. It occurs when I edit the 2D symbol, but occasionally happens when populating or editing the fields. I recently noticed that sometimes when this happens the sheet border symbol is still in the resource browser but that the record format associated with the symbol has vanished. I am not certain if this is always the case. Quote Link to comment
0 DMLA Posted September 16, 2016 Share Posted September 16, 2016 Any news on a solution for this? I am having exactly the same issue. All information associated with the title block disappears, the title block border disappears and it also moves location. This happens every time I attempt to edit both the 2D component or any of the information fields. Quote Link to comment
0 Bear Dizzle Posted October 19, 2016 Share Posted October 19, 2016 I've seen a couple of posts on this issue but have not seen a resolution so I thought I would repost. I'm having issues with a disappearing sheet border. Anytime I update the border (either through the issue manager, object info palette, or even renaming a sheet layer through the layer manager) the sheet border will disappear. It still shows up as selected in the object info palette but if I were to hit escape and then select all, the sheet border will not be in the selection set. Now, if I completely shut down my computer (not restart and not just quitting VW) then reopen the file the problem temporarily goes away, but then comes right back the next time I open the file. Any thoughts? Quote Link to comment
0 RussU Posted October 19, 2016 Share Posted October 19, 2016 (edited) Yes.... I've had this problem since 2014... It's not that the border has dissapeared as such, it's just mysteriously become HUUUUGGGGGEEEE!!! Try (while keeping the border selected) to do a "zoom all" (ctrl+num6 on pc) and you should zoom out a load and see your massive border with a teeny tiny page in the middle. go to the oip, and select (for arguments' sake) page size A2, and then back to your original size and it should snap back into normal position, quick as a flash. Just as a head's up though, I reported this issue in 2014, 2015, 2016 and now you say 2017 also? Interesting that it's still un-patched. If you do end up getting really bored, swearing and doing that trick over again, I found that a nice cup of tea, while playing with the other tools that are cool but you'll never use helps you forget about the borders. It's not like you use borders all the time? I mean... a sense of perspective needed, people!!! I must admit, this problem faded into insignificance when I had a lot of steel arrive on site with errors because of a silly tool fault. The client stopped calling me and as such they never heard about my "software problems" again!!! Perhaps if you cancel your clients, you won't have the sheet border problem again. I've learned that not drawing anything and playing Flight Simulator instead tends to reduce the error ratios a lot, and gives you a nice sense of achievement. The sheet border error actually helped me learn to land flawlessy on an aircraft carrier in the fog with a strong cross wind.... nice.. Dear VW.... Please don't fix the old border issue or any of the other buggy and painful tool errors until the new year... I'm so close to mastering how to land a 747 in a windy 1980's Hong Kong. Edited October 19, 2016 by RussU Quote Link to comment
0 Bear Dizzle Posted October 20, 2016 Share Posted October 20, 2016 Thanks for the reply but no luck. I tried zooming to all and nothing happened. I manually zoomed way out and still nothing. One new development however, it seems I can now recreate the problem on demand. When you select "edit issue data" on the OIP it opened up the issue data dialogue box, now if I hit the esc key to close out that box the sheet border disappears and anytime I touch it with any other tool after that it disappears. Quote Link to comment
0 Vectorworks, Inc Employee PVA - Admin Posted October 20, 2016 Vectorworks, Inc Employee Share Posted October 20, 2016 Post a file with that title block please and I can take a closer look. It can just be the title block on its own if that causes the same problem on your end. I was unable to replicate it here but with title blocks there are a lot of variables to check. Quote Link to comment
0 Bear Dizzle Posted October 20, 2016 Share Posted October 20, 2016 Hi Jim, Please see attached. This is the title block we are using. I removed several design layers and sheet layers to get the file down to size. 14055-Master.vwx Quote Link to comment
0 Vectorworks, Inc Employee PVA - Admin Posted October 20, 2016 Vectorworks, Inc Employee Share Posted October 20, 2016 This looks live a Vectorworks 2015 file, what version of Vectorworks are you currently using? Quote Link to comment
0 Bear Dizzle Posted October 20, 2016 Share Posted October 20, 2016 VW 2015. We're supposed to be transitioning to 2016 in the next few weeks. Quote Link to comment
0 Vectorworks, Inc Employee PVA - Admin Posted October 20, 2016 Vectorworks, Inc Employee Share Posted October 20, 2016 I'm not able to replicate the disappearing in 2016 or 2017, if you get a chance to use the demo of the latest version let me know if you can replicate the issue there: http://www.vectorworks.net/trial/form Quote Link to comment
0 Andy Broomell Posted October 20, 2016 Share Posted October 20, 2016 Here's a thread which is perhaps related? I don't think there was resolution though. Quote Link to comment
0 Vectorworks, Inc Employee PVA - Admin Posted October 20, 2016 Vectorworks, Inc Employee Share Posted October 20, 2016 Merging similar thread, this is now an active bug being tracked. VB-129003 Quote Link to comment
0 Taproot Posted October 21, 2016 Share Posted October 21, 2016 I have a worksheet that catalogs the drawing border for inclusion in my drawing index. I noticed a corruption of my template file where a number of "ghost" borders would appear in the index. They represented titleblocks that had disappeared and were uneditable. It made the drawing index unusable. On August 2nd (this year), I finally followed up with Joseph Block (tech support) to get some help. He was able to fix it on his end and my file is healthy again. I assume the file and his solution are in your database somewhere and may assist you in correcting the problem. 1 Quote Link to comment
dancraig
Hey all,
Dan
Top Posters For This Question
6
5
4
3
Popular Days
Oct 21
8
Oct 20
8
Nov 17
5
Feb 7
3
PVA - Admin 6 posts
Bear Dizzle 5 posts
dancraig 4 posts
rDesign 3 posts
Popular Days
Oct 21 2015
Oct 20 2016
Nov 17 2016
Feb 7 2018
Popular Posts
Kevin McAllister
Thanks for the followup! Too early to tell. I've only had TBBs disappear in VW2020. Most of the other sheet layer issues seem to be resolved so far. If I can find a
AlanW
Andy Broomell
68 answers to this question
