DomC
Worksheet image with "if" statement
Hi
Maybe not the right forum for worksheet formula questions.
I am searching a way to insert an image in a worksheet cell by using a formula. I already searched the forum but could not find any related questions.
What I am trying to do:
If want to show an image in cell D1, if the cell A1 has the value greater than "0".
=if((A1<>0), 'here i want an Image', 'false')
I tried this:
=IF((A1<>0), (IMAGE(N='k1')), '') #-> cell is empty
=IF((A1<>0), D1, '') #D1 is refering to the cell "D1" which shows the image by =IMAGE(N='k1')
=IF((A1<>0), IMAGE(N='k1'), '') #-> cell is empty
also tried from other direction:
=IMAGE((IF((A1<>0), "N='k1'", ''))) #-> error because of the double quote I think
=IMAGE(E1) #Simple test, if IMAGE() formula can use values from other cells
I give up... Any tips?
Edited by DomC
One step nearer to the solution ... anything goes with script, forget crampy worksheet formulas.
#Formula in Worksheet: =RUNSCRIPT('script-1')
#python script-1:
A1=vs.CellValue(1,'A')
pic=vs.GetObject('pic-1')
if A1 >= 0:
pic=vs.GetObject('pic-2')
vs.WSScript_SetResImage(pic)
"Just" have to find cell number, the script runs. To read out relative cells to the script cell.
Interesting approach Dom, haven't tried to scripts via worksheets but they look they could solve alot of headaches..
Does anyone have a sample worksheet using RunScript in a cell? I cannot get any scripts to run.
using Vectorworks Architect 2016 on OS X
thanks for any help.
Hi
Attached, an Example.
Dom
1. Script in the cell:
=RUNSCRIPT('kantenbild-script')
2. Script which will be executed:
sheet_h=vs.ActSSheet()
if sheet_h != None and vs.GetName(sheet_h)!='XGST-VSSM Liste mit KB':
numRows, numColumns=vs.GetWSRowColumnCount(sheet_h)
startrow=9
rows=numRows-startrow
for x in range(rows):
	kabi=[]
	k=[]
	k1=vs.GetWSCellString(sheet_h,x+startrow, 14)
	k2=vs.GetWSCellString(sheet_h,x+startrow, 16)
	k3=vs.GetWSCellString(sheet_h,x+startrow, 18)
	k4=vs.GetWSCellString(sheet_h,x+startrow, 20)
	k=([k1],[k2],[k3],[k4])
	for i in range(4):
		if k[i] !=['']:
			kabi.append('1')
		if k[i] ==['']:
			kabi.append('0')
	vs.SetWSCellVertAlignment(sheet_h, startrow, 24, numRows, 24, 3)
	vs.SetWSColumnWidth(sheet_h, 24, 24, 37)
	vs.SetWSImgSizeType(sheet_h, x+startrow, 24, x+startrow,24, 1)
	vs.SetWSImgSize(sheet_h, x+startrow, 24, x+startrow, 24, 48, 48)
	vs.SetWSRowHeight(sheet_h, startrow, numRows, 37, True, True)
	vs.SetWSCellFormula(sheet_h, x+startrow, 24, x+startrow, 24, '=IMAGE(N=\'n.vssm.k'+str(kabi[0])+str(kabi[1])+str(kabi[2])+str(kabi[3])+'\')')
