Worksheet cell total count??
I have no clue what i should name this topic!
Here we go, I have symbols with a single record attached.
within the record there are 5 fields that are for a length breakdown
ex. b1, b2, b3, b4, b5
typically i will but the lengths needed in each cell
ex.
b1=100
b2=100
b3=50
b4=25
b5=0
That being said i have a worksheet that has criteria to look for the 'record being present' Record name is 'Cable'
Then add ('Cable'.'b1')+('Cable'.'b2')+('Cable'.'b3')+('Cable'.'b4')+('ANW'.'b5')
Then sort and sum that column.
The solution i am getting is not ideal, it is add up the number of occurrences that it see the total added length.
EX. =275
I am trying to solve how many time '100' or '50' or '25' occurs within the range of cells. The result I am looking for is;
25=1
50=1
100=2
i have has success with this in a singe record/field, but not trying to total up a range of record/fields
Did i over think it, or do i need to do a database for each record/field (b1, b2, b3, b4, b5) Then a separate database looking to those results to total up??
Or do i need to get really wordy and specify the Record Name & Field Value?
I was hoping it would auto populate whatever length is in the field value.
Thanks in advance,
Drew
Edited by chstech
I don't think there is an easy solution as you would have using excel. Keeping that in mind wouldn't it be easier to create a worksheet showing each length in a seperate column and porting it into excel ?
On the other side you can create a separate if(.a1 == 25)... criteria for each field or you use a script to print the data instead.
I think you could use Count(criteria), using the 'set criteria' function on the Datbase header cell.
Example from Worksheet Functions : Vw2015 Online Help:
Database header cell:
=Count
(returns the total number of objects for each row in the database)
Spreadsheet cell:
=Count(s='simple sofa')
(returns the total number of symbol objects named “simple sofa” in the drawing)
See these related posts for further info on using Count with 'set criteria':
seating layout question
Vectorworks 2014 Symbol Count?
Count Function and And Function
Or take a look at this thread that recommends using a Report instead of worksheet:
Counting Symbols in a Worksheet
rDesign,
Not needing to add 'Count' function since i am using a database looking to the record.
I have success with totaling the unique values within each record/field using the database
=('Cable'.'b1') then pull the 'Sum' over the database, add 1 to the next cell to get the qty
I am not having any luck with totaling the unique values within each record/field for a range ('Cable'.'b1')+('Cable'.'b2')+('Cable'.'b3')+('Cable'.'b4')+('Cable'.'b5')
No worries, appreciate the help. I am just looking for a little more than what i think VW is capable of right now without doing a lot of 'put info here' and then have the worksheet look to multiple database counts to total up.
And thanks for pointing me to James's post!
Edited by chstech
