Gaspar Potocnik
Hoist Tool Personalization
Is there a way to change the default Hoist Data Display selections for a new drawing? I know you can go in and change it for all new hoists in the "Set Hoist Data Display" menu; however, I am having to do it every time I open a new drawing.
The ability to view hoists by there function is a must.  Currently it's very difficult to create different views showing only hoists used for specific functions...
Hoist can be displayed by function or manufacturer by setting the Display Hoist By: option in the OIP.
To change any of the default values for all new documents you will need to use the plug-in manager to change the default value.
Select the plug-in then select the parameter you wish to change the default. Click Edit and then change the Default Value.
Thanks Klinzey! I will look into that feature in the future.
I realized I could create a template file, so I setup all my tool preferences and default classes there and utilize that template when needed.
To continue with this topic...
I`m trying to add new Hoists to be placed with Hoist tool. Seems not to work. I`ve created symbols in Chain Hoist Symbols.vwx and saved it attached records, restarted Vectorworks etc, but still doesn't work. What am I missing?
What did you name the symbols you created?  I think the rules below need to be followed:
The name must start with word "Hoist", followed by the weight capacity, followed by the manufacturer or function, followed by "Up" or "Down".
The weight capacity must end in the word "Ton".
The manufacturer may be anything, but must match the value in the attached record.
The function may be anything, but must match the value in the attached record.
Feel free to send me an example of your hoist symbols, and I'll see if I can get them to work.
Sam
sjones@autoplotvw.com
Coming back to this topic after a few years...
So I’ve redone symbols so that everything is uses classes that work for me, but I still haven’t been able to change de default class of the label. I’ve edited the string in the plug in but still it isn’t changing, what am I missing?
Sam
Hi!
I am also adding a few customized symbols into the Chain Hoist base library file, in order to fulfill some requirements of our rigging and subcontract suppliers.
Anything else I should be aware of?
I'm just changing the names and adding a weight load to the custom hoists "name", so that they will populate a "Legend" worksheet.
The issue I'm having is that the Hoist Tool is great for workflow, but I haven't figured out how to put their details into the Worksheet (name, weight, capacity, chain length, etc.)
  • Legend is required for our vendors (manufacturer, weight, capacity, department)
  • Hoist tool will only add from the library file
  • Renaming the imported symbols (once they are on the rigging request doc) to properly populate the worksheet to fulfill rigging req's
  • Adding a new hoist on revised doc adds the base symbol again into the resource manager
  • Select new hoists and "Replace..." with custom symbol
  • Recalculate worksheet
  • every event
The solution to me is to just bite the bullet and create new symbols that can be chosen from the beginning, for each department. Anyone else have any ideas? Thanks!
It would be awesome if the tool could allow Symbol selection like the "Insert Truss" plugin...
I typically do not use the hoist tool, but is there a way to display dimensions without the arrows?  Those take up way too much real estate in a complicated or crowded drawing. A simple xxx , yyy coordinate would certainly suffice.
Edited by scottmoore
The X and the The quick answer is no.  However...
You can click on the "Set Hoist Data Display..." button in the OIP of the Hoist and choose to display the X and the Y, but that won't save you much.  To get exactly what you want, I'm afraid your stuck with typing it in.
To a more philosophical thread, a simple xxx, yyy might suffice for you and, that's great, but considering the many different origins one can measure from in most cases, the current display is the most efficient and clear, at least according to the scores of riggers that beta tested it.  Identifying the direction of the origin is crucial and allows different hoists to measure from different places.
On 4/12/2016 at 3:50 PM, Sam Jones said:
Select the menu command
Spotlight / Hoists / Set Hoist Number and Dimension Display...
In the resulting dialog, enter the font size.
Wow Thannk you Sam! have been strugeling with this for soo long!
