simbob 1 Posted September 24, 2015 What's the best way to create an image for presentation purposes once your render has completed? I tried exporting as jpeg but it is such a long winded process as it has to re-render several times over. In the past i've just done a screen shot and used that. I wondered if setting up a viewport with fully rendered view and saving as PDF may be a quicker option as i can then add title block etc... Thoughts? Practices? Quote Share this post Link to post
PVA - Jim 2,395 Posted September 24, 2015 The FASTEST way is to select the rendered viewport, copy and then simply paste into Photoshop or whatever image editor you prefer, it will save the rendered bitmap to the clipboard. For image export, make sure to uncheck the two Update/Reset options at the bottom of Image Export and it wont require a rerender for marquee selection mode. However I recommend PNG and 150DPI settings, as the default JPEG settings are really low quality. Quote Share this post Link to post
CipesDesign 153 Posted September 24, 2015 The fastest way, on a Mac, is to do a cropped Screen Shot. Hit Command+4 then use the cursor to "frame" or "crop" the image (that way it doesn't show the entire desktop. This will drop a PNG image onto your desktop. This image can then be renamed, recropped, or you can Save-As to a different format (PDF, JPEG,etc.). Note that this is a fairly low-res image. Perfect for quick emailing, etc. Quote Share this post Link to post
simbob 1 Posted September 24, 2015 Thanks Peter, that is the way i currently do it but it's not great for printing or if you need to make the image bigger. Thanks Jim, i will try this Quote Share this post Link to post
zoomer 1,130 Posted September 24, 2015 A solution is urgently needed. I think the workaround was to convert each camera to a Viewport. You could put these into the Publish Manager to batch Render and Save these. I think the manual way would be by "Export Image File" of a Viewport. If I got it right, that still means to do a Marquee manually. I'm not sure how to avoid the Marquee needed in Publisher. Either it needs to set a Sheetlayer for each Camera/Viewport and scale the viewport to full paper size, or some other way. Then you could try to set a custom DPI setting like "183,74 DPI" to get your wanted Pixel Size of f.e. 2400x1800 at the end. Quote Share this post Link to post
rDesign 479 Posted September 24, 2015 What's the best way to create an image for presentation purposes once your render has completed? I tried exporting as jpeg but it is such a long winded process as it has to re-render several times over. In the past i've just done a screen shot and used that. I wondered if setting up a viewport with fully rendered view and saving as PDF may be a quicker option as i can then add title block etc... Thoughts? Practices? @simbob: I do your last thought and set up Sheet Layers with rendered viewports as I find it works pretty quickly and consistently. When I present design options, I create several 8.5"x11" or 11"x17" sheet layers and put a rendered SLVP of the RW camera view on each sheet, one to a page. Then I can add title block, date, title, etc. SK101 - Option A - View 1 SK102 - Option A - View 2 SK103 - Option A - View 3 ... You can then either export all of those SL one at a time as individual PDFs or batch them with the Publish command. If PDFs are in color and I don't want to show colors yet, I have an Automator script (on Mac OSX) that converts them to greyscale via drag-and-drop. When I need to present design option B, C, D & E it is just as easy as duplicating all of those SL, renaming & renumbering them, and changing the class and layer visibility for the various options. Since duplicating the SL also duplicates the SLVP, I know that the different options will have the same exact camera view. I find it is a pretty quick and easy workflow. When it comes time to make Constructiion Documents, I can copy or move those SLVP to a sheet in the drawing set. I don't export images from a Design Layer because, as I understand it, it is rendering at full-resolution and will take much longer to render than if you had set up a SLVP where you can control the size and dpi of the rendering. Quote Share this post Link to post
AlanW 547 Posted September 25, 2015 (edited) One thing I found was that if after you render the viewport it should export immediately, unless you have "update visible out of date viewports prior to exporting" ticked. (Bottom Left) I couldn't figure out why it was stalling till I realized I had about 10 viewports across the page that the program started to render after I tried to export. Edited September 25, 2015 by Alan Woodwell Quote Share this post Link to post
sle7en7 1 Posted November 21, 2016 Could someone clear the situation of overriding stuff in these Camera linked SLVPs? I'm specifically interested in the camera DPI and the sheet layer DPI, how do they relate to each other? Going along with that how does the rendering style and the environment the camera was set in relate to each other? For example rendering background settings and environment lighting settings? When I leave the option of the rendering style's background to get from "current background" that background is the background which the camera was originally setup-in right? Quote Share this post Link to post
PVA - Jim 2,395 Posted November 21, 2016 If you're making a sheet layer viewport, then the sheet layers DPI is all you need to concern yourself with, the Camera's doesn't appear to affect it. The Rendering style and background are overridden by the setting on the viewport, which is how I always control it after the viewport is created. "Current Background" will pull the background applied within the design layer, I do not believe it remembers what background was used at the time of camera creation. Quote Share this post Link to post
sle7en7 1 Posted November 21, 2016 Ok thanks for clearing that out Jim. Quote Share this post Link to post
Phil hunt 76 Posted November 21, 2016 I always use the marquee crop and then I set my dpi and print size from thei rendered viewport i set my image size to 300 mm wide depth in pro so 300 mm x 200 mm A4 size export dpi 300 and save as tiff used to save as Photoshop but like the tiff file better Quote Share this post Link to post
Phil hunt 76 Posted November 21, 2016 Sorry then take this into photoshop, illustrator to do the presentation finals. Quote Share this post Link to post
Luis M Ruiz 262 Posted November 21, 2016 Since over here is exactly the process we go thru every year when creating tons of renderings for brochures I have to say the best process is: Set your view > create viewport > set layer to 300 dpi (final target) > size your page to B size > set your rendering style > update viewport at low res if need a quikc review (50dpi) > create final render > don't forget to save viewport cache just in case you close the file > export to PDF, that is if your graphic designer needs to tailor some of those vector lines. Quote Share this post Link to post
