IS THERE A DE-SELECT COMMAND?
simbob
It's quite annoying when, having set up a view to render, you realize something is selected and has an orange outline. You then need to exit the view to deselect (click off the drawing objects) and then go back to the view.
Can you de-select all items at the touch of a button?
I think this is a Situation where X + X should work.
I was used to click in free space to deselect everything, which works
as long there is a free space without objects.
A little comfort may be that you can can do this After you rendered a View
Without destroying the Rendering, if you forgot it before.
(In most cases ?)
