dwdavedw Posted September 23, 2015 Share Posted September 23, 2015 How do you copy and paste lighting device info from one unit to another - i.e. all channel, dimmer, purpose, etc. Quote Link to comment
markdd Posted September 24, 2015 Share Posted September 24, 2015 Use the Eyedropper tool to change the whole fixture and all its device info. Alternatively you can select multiple fixtures and enter the data that way. That's the only way I can think of... Mark Quote Link to comment
dwdavedw Posted September 24, 2015 Author Share Posted September 24, 2015 Eyedropper - great idea, only problem is it also changes unit number - wish there was a way to choose what parameters to copy/paste - the prefs are limited in terms of lighting units, looks like all or none for what's most useful - channel, dimmer, circuit, color, gobo, etc. Seems there should be a way. I can do it lightwright, but not as clean as VW solution. Quote Link to comment
Shac Posted September 27, 2015 Share Posted September 27, 2015 You can use the find and modify command. Under the spotlight menu. Another tool is autoplotvw which is a plug in with lots of commands for $35 Quote Link to comment
