Vertical type problems when printing pdf
In the Print dialog box, select VectorWorks from the drop down box.
Checkmark "Disable driver text rotation".
The text should print correctly then.
If it mushes up, don't tab out of the VW until the PDF is written.
Katie,
Like Adam E states, there is no normal Print dialog box when printing to the pdf writer... you get the pdf writer dialog box which doesn't have the normal pull down menus... Is there another way to print to the pdfwriter using the normal print dialog box? Note that I'm using system 9.2.5, not OSX. Thanks
Oh, duh... it's not in a pull down menu, but right there in front of my face! I tried it and it works fine. Now I really feel stupid....
